can somebody please provide me some information/documentation about the watchdog (beta) which is getting optionally installed with litespeed oneclick install (sh <(curl https://cyberpanel.net/install.sh || wget -O - https://cyberpanel.net/install.sh))
(couldn’t find much on the google )
Thank you
I’ve enabled it too, how can I deactivate it? there was a hint about deactivating it while the installer running but I didn’t saved that command
found this:
“If the Watchdog detects a problem, it automatically restarts the service. Watchdog is in the beta stage, so it may not be 100% stable. But then again, Watchdog can help to keep your website running smoothly.”
And how do you install it if we didn’t choose it at the beginning?
