How to upgrade MariaDB and OpenLiteSpeed version? In OLS is currently using 1.4 and 1.5 has just been released, also, when I installed MariaDB it was with another version and there is a new one, “yum upgrade” does not do this.
for OLS you can just yum update openlitespeed
, source code is always prior to yum package so it may have some delay before yum package is out.
what mariadb version you installed ?
for OLS you can just `yum update openlitespeed`, source code is always prior to yum package so it may have some delay before yum package is out.what mariadb version you installed ?
That did not work, still running 1.4, I am running MariaDB 10 as it was the stable at the moment I installed CyberPanel
Any word on this @CyberPanel ?
Keep the same MariaDB version for now. For OLS you can do
yum update
yum upgrade openlitespeed
