upgrade cyberpanel 1.9.1 to 1.9.2 failed
In regards to this issue
Try the following as su - root
wget https://raw.githubusercontent.com/usmannasir/cyberpanel/stable/plogical/upgrade.py
/usr/local/CyberPanel/bin/python upgrade.py
If that fails, try to fix venv by following (taken from preUpgrade.sh except deactivate bit part)
virtualenv --system-site-packages /usr/local/CyberPanel
source /usr/local/CyberPanel/bin/activate
rm -rf requirments.txt
wget https://raw.githubusercontent.com/usmannasir/cyberpanel/stable/requirments.txt
pip install --ignore-installed -r requirments.txt
deactivate
then try to rerun upgrade
you might want to manually set CyberPanels venv
Thank you so much. It’s working now
