CyberPanel Community
Update problem
pa
pasamsin #1
I am using CentOS 7, and when I try to update CyberPanel, I encounter some errors below and receive a 503 error when trying to access the panel.
[11.07.2024_10-44-58] #########################################################################
[11.07.2024_10-44-58] Remove old static content successful.
  File "manage.py", line 22, in <module>
  File "/usr/local/lib/python3.8/site-packages/django/core/management/__init__.py", line 401, in execute_from_command_line
    utility.execute()
  File "/usr/local/lib/python3.8/site-packages/django/core/management/__init__.py", line 377, in execute
    django.setup()
  File "/usr/local/lib/python3.8/site-packages/django/__init__.py", line 16, in setup
    from django.urls import set_script_prefix
  File "/usr/local/lib/python3.8/site-packages/django/urls/__init__.py", line 1, in <module>
    from .base import (
  File "/usr/local/lib/python3.8/site-packages/django/urls/base.py", line 9, in <module>
    from .exceptions import NoReverseMatch, Resolver404
  File "/usr/local/lib/python3.8/site-packages/django/urls/exceptions.py", line 1, in <module>
    from django.http import Http404
  File "/usr/local/lib/python3.8/site-packages/django/http/__init__.py", line 5, in <module>
    from django.http.response import (
  File "/usr/local/lib/python3.8/site-packages/django/http/response.py", line 15, in <module>
    from django.core.serializers.json import DjangoJSONEncoder
  File "/usr/local/lib/python3.8/site-packages/django/core/serializers/__init__.py", line 23, in <module>
    from django.core.serializers.base import SerializerDoesNotExist
  File "/usr/local/lib/python3.8/site-packages/django/core/serializers/base.py", line 7, in <module>
    from django.db import models
  File "/usr/local/lib/python3.8/site-packages/django/db/models/__init__.py", line 20, in <module>
    from django.db.models.fields.files import FileField, ImageField
  File "/usr/local/lib/python3.8/site-packages/django/db/models/fields/files.py", line 8, in <module>
    from django.core.files.storage import Storage, default_storage
  File "/usr/local/lib/python3.8/site-packages/django/core/files/storage/__init__.py", line 3, in <module>
    from django.conf import DEFAULT_STORAGE_ALIAS, settings
ImportError: cannot import name 'DEFAULT_STORAGE_ALIAS' from 'django.conf' (/usr/local/lib/python3.8/site-packages/django/conf/__init__.py)
[11.07.2024_10-44-58] Remove old static content failed, trying again, try number: 1
    utility.execute()
    django.setup()
    from .base import (
[11.07.2024_10-44-59] #########################################################################
[11.07.2024_10-44-59] Remove old static content failed, trying again, try number: 2
    utility.execute()
    django.setup()
    from .base import (
[11.07.2024_10-44-59] Remove old static content failed, trying again, try number: 3
[11.07.2024_10-44-59] Remove old static content failed.
1 reply
pa
pasamsin #2
/usr/local/lscp/cyberpanel/logs/error.log
ExtConn timed out while processing.
