After upgrading to 1.94, I am unable to login to the panel. It is stuck forever at the login page after hitting the sign in button.
OS - Centos 7
Litespeed version - OLS
OS - Centos 7
SOS
Even when the ports are open? Firewall is not blocking the connection.
For my part, on 2 servers, I can’t even reach the login page on port 8090 after upgrade to 1.9.4. I tried disabling MySQL binary logging to no success. I get error 500 or 503.
Do you have an idea what could be the issue?
The same problem
Not working > @CyberPanel said:
Disable MySQL binary logging → Hartwork Blog · How to disable MySQL binary logging
Not working
same problem
@CyberPanel don’t work still error 503
MariaDB [(none)]> SHOW VARIABLES LIKE ‘log_bin’;
| Variable_name | Value |
| log_bin | OFF |
1 row in set (0.00 sec)
FYI, bug has been fixed. Just upgrade again.
same problem after upgrade
i find the solution
/usr/local/CyberCP/loginSystem/templates/loginSystem/login.html
/usr/local/CyberCP/baseTemplate/templates/baseTemplate/index.html
/usr/local/CyberCP/filemanager/templates/filemanager/index.html
after that “reboot” your server
Type your comment> @samyhossam said:
The same problem
Not working > @CyberPanel said:Disable MySQL binary logging → Hartwork Blog · How to disable MySQL binary logging
Not working
Make sure that there’s no log-bin
line anywhere else in your /etc/my.cnf
Verify that binary logging is disabled my running SHOW VARIABLES LIKE 'log_bin';
in mysql and confirm it’s OFF.
i have same issue and this is how to fix it.
these are the steps:
/etc/mysql/my.cnf
log-bin
and comment that line (give #
sign on front)service mysql restart
now, you will able to login your cyberpanel again. i hope these steps works for you.
