Where can I find the complete logs after install?.
Provider: Niagahoster
Virtualization Type: OpenVZ
System: Centos 7 64bit Minimal
Fresh install on Centos 7 64bit Minimal
sestatus
status disabled
yum update -y
grep: /etc/selinux/targeted/rpmbooleans.custom: No such file or directory
ValueError: SELinux policy is not managed or store cannot be accessed.
warning: %postun(bind-32:9.9.4-73.el7_6.x86_64) scriptlet failed, exit status 1
Non-fatal POSTUN scriptlet failure in rpm package 32:bind-9.9.4-73.el7_6.x86_64
Cleanup : 32:bind-libs-9.9.4-73.el7_6.x86_64 10/12
Cleanup : 32:bind-license-9.9.4-73.el7_6.noarch 11/12
Cleanup : glib2-2.56.1-2.el7.x86_64 12/12
/var/tmp/rpm-tmp.qFjlje: line 12: /etc/selinux/targeted/rpmbooleans.custom: No such file or directory
/var/tmp/rpm-tmp.qFjlje: line 30: /etc/selinux/targeted/rpmbooleans.custom: No such file or directory
warning: %posttrans(bind-32:9.9.4-74.el7_6.1.x86_64) scriptlet failed, exit status 1
Non-fatal POSTTRANS scriptlet failure in rpm package 32:bind-9.9.4-74.el7_6.1.x86_64
cd ~
wget -O installer.sh https://cyberpanel.net/install.sh
Resolving cyberpanel.net (cyberpanel.net)⌠2606:4700:30::681b:a395, 2606:4700:30::681b:a295, 104.27.163.149, âŚ
Connecting to cyberpanel.net (cyberpanel.net)|2606:4700:30::681b:a395|:443⌠failed: Network is unreachable.
Connecting to cyberpanel.net (cyberpanel.net)|2606:4700:30::681b:a295|:443⌠failed: Network is unreachable.
Connecting to cyberpanel.net (cyberpanel.net)|104.27.163.149|:443⌠connected.
HTTP request sent, awaiting response⌠200 OK
Length: 494 [application/x-sh]
Saving to: âinstaller.shâ
chmod 755 installer.sh
sh installer.sh
OLS or Enterprise?
OLS
Official
no
no
Install LiteSpeed Memcached?
yes
Install Memcached?
This option was not shown
yes
Install Redis?
yes
CyberPanel Successfully Installed
Current Disk usage : 3/20GB (19%)
Current RAM usage : 206/1024MB (20.12%)
Installation time : 0 hrs 19 min 34 sec
Visit: https://156.67.221.99:8090
Panel username: admin
Panel password: xxxxxxxxxx
Please change your default admin password
If you need to reset your panel password, please run:
adminPass YOUR_NEW_PASSWORD
If you change mysql password, please modify file in
/etc/cyberpanel/mysqlPassword with new password as well
Website : https://www.cyberpanel.net
Forums : https://forums.cyberpanel.net
Wikipage: https://docs.cyberpanel.net
Enjoy your accelerated Internet by
CyberPanel & OpenLiteSpeed
Some warning or error I can find in in terminal after process finished.
Cannot uninstall requirement pyOpenSSL, not installed
You are using pip version 8.1.2, however version 19.1.1 is available.
You should consider upgrading via the âpip install --upgrade pipâ command.
Cannot uninstall requirement certbot, not installed
[Tue Jun 18 03:59:35 UTC 2019] It is recommended to install socat first.
[Tue Jun 18 03:59:35 UTC 2019] We use socat for standalone server if you use standalone mode.
[Tue Jun 18 03:59:35 UTC 2019] If you donât use standalone mode, just ignore this warning.
System check identified some issues:
WARNINGS:
?: (mysql.W002) MySQL Strict Mode is not set for database connection âdefaultâ
HINT: MySQLâs Strict Mode fixes many data integrity problems in MySQL, such as data truncation upon insertion, by escalating warnings into errors. It is strongly recommended you activate it. See: Databases | Django documentation | Django
?: (mysql.W002) MySQL Strict Mode is not set for database connection ârootdbâ
gcc -pthread -fno-strict-aliasing -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -DNDEBUG -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -O0 -g3 -I. -I/usr/include/python2.7 -I. -I/usr/include/python2.7 -c -o main.o main.c
In file included from /usr/include/inttypes.h:25:0,
from ./lsapidef.h:37,
from ./lsapilib.h:41,
from main.c:34:
/usr/include/features.h:330:4: warning: #warning _FORTIFY_SOURCE requires compiling with optimization (-O) [-Wcpp]
main.c: In function âmainâ:
main.c:169:9: warning: implicit declaration of function âpreload_moduleâ [-Wimplicit-function-declaration]
preload_module(moduleName, appName, progName);
gcc -pthread -fno-strict-aliasing -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -DNDEBUG -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -O0 -g3 -I. -I/usr/include/python2.7 -I. -I/usr/include/python2.7 -c -o wsgi.o wsgi.c
In file included from /usr/include/limits.h:26:0,
from /usr/lib/gcc/x86_64-redhat-linux/4.8.5/include/limits.h:168,
from /usr/lib/gcc/x86_64-redhat-linux/4.8.5/include/syslimits.h:7,
from /usr/lib/gcc/x86_64-redhat-linux/4.8.5/include/limits.h:34,
from /usr/include/python2.7/Python.h:19,
from wsgi.c:29:
gcc -pthread -fno-strict-aliasing -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -DNDEBUG -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -O0 -g3 -I. -I/usr/include/python2.7 -I. -I/usr/include/python2.7 -c -o wsgiinput.o wsgiinput.c
from wsgiinput.c:29:
gcc -pthread -fno-strict-aliasing -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -DNDEBUG -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -O0 -g3 -I. -I/usr/include/python2.7 -I. -I/usr/include/python2.7 -c -o wsgiwrapper.o wsgiwrapper.c
from wsgiwrapper.c:29:
gcc -pthread -fno-strict-aliasing -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -DNDEBUG -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -O0 -g3 -I. -I/usr/include/python2.7 -I. -I/usr/include/python2.7 -c -o lsapilib.o lsapilib.c
In file included from /usr/include/ctype.h:26:0,
from lsapilib.c:35:
gcc -pthread -fno-strict-aliasing -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -DNDEBUG -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -O0 -g3 -I. -I/usr/include/python2.7 -I. -I/usr/include/python2.7 -c -o lsapi-glue.o lsapi-glue.c
from lsapi-glue.c:33:
gcc -pthread -Wl,-z,relro -L/usr/lib64 -Xlinker -export-dynamic -o lswsgi main.o wsgi.o wsgiinput.o wsgiwrapper.o lsapilib.o lsapi-glue.o -L/usr/lib64/python2.7/config -lpython2.7 -lpthread -ldl -lutil -lm
Username: admin
Password: 1234567
I can access the web panel without any issue after cyberpanel installation finished. But after rebooting the VPS, then it stuck, canât even ping the VPS.
Thank you
My issue is back again. Same thing.
I am having the same issue when upgraded cyberpanel to 2.02 the latest I just canât access the admin anymore.
I have restarted the server several times but
Failed to start LSCPD Deamonn just canât find any solution
I canât access cyberpanel, OLS is running, the sites are running, but canât access cyberpanel.
Nobody can fix this error, i get this error and now back to Cpanel LOL
Try to unistall CSF with these commands in terminal
cd /etc/csf
sh uninstall.sh
In my case it worked fine and i install CSF again.
