BlazeFlare19 #1
In Arc Raiders, the Binoculars gadget is a useful tool for scouting areas from a distance, offering enhanced visibility without the need to directly engage with nearby enemies. However, one unique feature that can sometimes cause confusion is the ability to use Binoculars without the Heads-Up Display (HUD) enabled. In this guide, we’ll break down how this works in practice, what it means for gameplay, and how to make the most of the binoculars for optimal performance.
What are Binoculars in Arc Raiders?
Binoculars in Arc Raiders are a common gadget that players can use to scout enemy positions and get a clearer view of distant locations. Unlike other gadgets, Binoculars offer two levels of magnification, allowing you to zoom in and see a larger area from afar.
This gadget can be especially helpful during reconnaissance or when you need to track down enemies or valuable resources in the game. The basic version of the Binoculars comes with a weight of 0.5 and a stack size of 1, so it doesn’t take up much space in your inventory.
How to Use Binoculars without HUD
In most games, gadgets like Binoculars will show certain on-screen prompts or overlays, such as your health, enemy locations, and other important data. However, in Arc Raiders, using Binoculars without the HUD means you’ll be looking through them without these visual aids, giving you a more immersive experience.
Here’s what happens when you use Binoculars without the HUD:
  • No HUD Overlays: When you activate the Binoculars, you won’t see your health bar, the minimap, or other common HUD elements. This makes the view cleaner and more focused on what you’re observing, but it can also make you more vulnerable since you’ll need to rely on your instincts and situational awareness.
  • Zoomed-in View: The Binoculars offer two levels of magnification, which you can toggle between. This lets you zoom in on areas of interest. While the higher magnification can help you see details from far away, it also means you’ll have less of your surroundings in view, so be cautious of sudden threats.
  • Contextual Awareness: With the HUD off, you must pay close attention to the environment. The Binoculars help you gather information, but it’s easy to miss subtle changes in your surroundings, like moving enemies or shifting weather patterns.
Why Use Binoculars without HUD?
The choice to disable the HUD while using Binoculars may seem unconventional, but it can be a strategic decision. Some players prefer the immersion and focus that comes with a cleaner interface, which is especially useful when scouting for distant targets or looking for hidden items.
Here are some reasons why you might want to try using Binoculars without the HUD:
  1. Focus on Exploration: When you disable the HUD, you’re forced to concentrate on what you’re seeing, which can be an advantage during exploration or when trying to track a distant object or enemy. It enhances your focus on the surroundings, allowing you to spot items or hazards you might otherwise miss.
  2. Reduced Screen Clutter: Some players find the clutter of a full HUD distracting, especially when they need to make decisions quickly. By disabling it, you gain a more streamlined and cinematic experience.
  3. Immersion: Without the HUD, the game feels more like an adventure or survival experience, where you’re relying on your own observations instead of in-game indicators. This can make the game feel more real and rewarding, especially for long scouting sessions.
Crafting Binoculars
Binoculars are not just available to buy but can also be crafted, giving you more control over when and how you get your hands on them. To craft a pair of Binoculars, you’ll need the following materials:
  • 8x Plastic Parts
  • 4x Rubber Parts
These materials can be obtained through scavenging or crafting, and once you have everything, you can use a Utility Station to create your Binoculars.
Repairing and Recycling Binoculars
Like most items in Arc Raiders, Binoculars have a durability rating. Over time, they can become damaged and need repairs. To repair Binoculars, you’ll need:
  • 2x Rubber Parts
  • 4x Plastic Parts
The repair will restore the Binoculars’ durability by +50.
In addition to repairing, Binoculars can also be recycled. Recycling Binoculars will give you 2x Rubber Parts and 4x Plastic Parts, which can be useful for crafting other items. Salvaging Binoculars yields 4x Plastic Parts, so even if the item is no longer usable, it can still contribute to your crafting efforts.
Practical Tips for Using Binoculars
Here are a few tips to help you get the most out of your Binoculars, especially when using them without the HUD:
  • Take Your Time: Since you won’t have on-screen indicators, it’s important to take your time when using the Binoculars. Zoom in slowly and carefully observe the area for any movement or changes.
  • Check the Surroundings: Even though you’re using the Binoculars for a focused view, make sure to keep an eye on your surroundings to avoid surprise attacks.
  • Use the Zoom Sparingly: The higher magnification can sometimes limit your view, so use it only when absolutely necessary. At lower magnification, you’ll get a better sense of the larger area around you.
  • Prepare for Emergencies: Without the HUD, you won’t have a health bar or map to guide you. Make sure you’re in a safe area when using the Binoculars, or have a plan to escape in case enemies spot you.
The Arc Raiders Binoculars are a valuable tool for players who want to scout and plan ahead. Using them without the HUD enhances the immersive experience and requires a bit more focus and awareness. Whether you’re preparing for an ambush, exploring an unknown area, or just keeping an eye on enemy movement, the Binoculars can be a game-changer.
If you’re looking for ways to improve your arsenal, you can also buy ARC Raiders blueprints cheap with U4N deals, helping you build up your resources and expand your options as you venture through the game.
