Hi I get the following error when I enter the “Top Process” section
Error:
Operation Failed!
invalid literal for float(): 19779694+total,
CyberPanel → 1.8 - 3
Centos 7
Error:
Operation Failed!
Centos 7
Will check
Provide more details about your provider (virtualization) and system language?
physical server (Dedicated). Not a virtual server.
System: Centos 7.6
system language = eng
Provider: Online.net
OLS or Enterprise? = OLS
Interesting, you had this error earlier, or happened just after the upgrade? Or you just noticed now?
I have no problems with my old server. I bought a new server. and I installed a cyber panel. This error is output when I enter “top processing”.
Kindly submit support ticket with login details.
