Today I’m Doing Some SSL Testing on My New SSL Certificate.
But I Got This Error:
i Didn’t See Any Option To Fix it on CyberPanel
Please Help
what SSL cert you are using ?
you will need to add CA cert into your cert
I assume your cert file is look like this:
-----BEGIN CERTIFICATE-----
This is your end cert
-----END CERTIFICATE-----
this is your end cert , you need to add intermediate or CA cert into it
you can find your missing middle/root cert here
https://whatsmychaincert.com/
https://certificatechain.io/
so when you got the middle/root cert , it’s similar as your site cert, you will need to combine them , which the new cert will be like this:
This is your middle or root cert
save the file and replace it in
/usr/local/lsws/conf/vhosts/SSL-your_domain_com/fullchain.pem
and restart OLS
Solved. Thank You Very Much
