I’m using an invoicing app crater which requires to have a custom document root to $VH_ROOT/public_html/crater/public . Now when I first installed the app the SSL was working fine but now suddenly it stopped working. SSL is working fine on all the other domains and subdomains. As this is the only one with a different document root I’m assuming this is causing the issue. I tried to issue SSL from manage SSL and I get an email with failed to obtain SSL. After inspection of the access file, I found out failed the acme-challenge due to a 404 error. I even tried to manually add SSL with
Thank you everyone for your help. Now I at least have SSL restored. I was hoping if there is a code or maybe an acme-challenge done by DNS or something to make it automatic.
Thank you for clearing that up. I really appreciate everyone’s quick responses. I wanted to mask out the links on my main post. Just don’t want any unwanted attention from hackers and spammers. Cannot find a way to edit the first post.
