Hopefully You guys are Doing well. I am new CyberPanel user but Yet I configured everything properly. Everything was Fine. Just I noticed that SSL is 2 types, 1. Self Assigned 2. From Let’s Encrypt Where Self Assigned SSL worth nothing but Now the Issue ssl is always showing Failed
What I already DID :
DNS Lookup
Fixes deleting previous .pem etc file
Followed official Guide
Turned of Antivirus
I am suspecting that the Folder is not Creating for any Reason even so if i manually create it is not Opening on https://mydomain.com/.well-known/…
The Path
Now I really need my Fellow Respective Usman nasir and Community Help
Sorry for Disturbing the Community but Fortunately I fixed it!..
For people’s I am letting it know what I did as a responsible member of CyberPanel
I just removed connection between Cloudflare and CyberPanel manually Setup the DNS then add the Connection which fixed my issue!..
Have a Nice day. I am Feeling like Legend Now after Trying ofr 7 Hours for the Same issue
I was been a developer days before. And I know some php html coding stuffs… Literally coming in Linux n VPS is another experiance!.. I already had to debug when I was php developer but Linux and CyberPanel debugging experiance forwarded me to another level!..
Hi , im facing the same issue but cant fix it , the url: https://litespeed.netgen.gr:8090/
suddenly they lost ssl,
I tried to enable-disable proxy, to Purge Cache on cloudflare to make ssl issue on that subdomain but nothing worked.
