SSL is not issued
Domain:
hosting.outsur.cc
Cloudflare:
Process:
What’s wrong?
re issue at your primary domain outsur.cc
then issue as hostname ssl
I didn’t understand.
I don’t use a domain outsur.cc
My domain hosting.outsur.cc
And I can’t issue at least a regular SSL for it.
As soon as I issue a regular SSL, I will make a hostname.
Hi!
Did you find the below code in earlier posts? Please run the code as root and post the output / fix the issue directly yourself :slight_smile: .
  1. sudo su -
  2. /root/.acme.sh/acme.sh --issue -d hosting.outsur.cc -d www.hosting.outsur.cc --cert-file /etc/letsencrypt/live/hosting.outsur.cc/cert.pem --key-file /etc/letsencrypt/live/hosting.outsur.cc/privkey.pem --fullchain-file /etc/letsencrypt/live/hosting.outsur.cc/fullchain.pem -w /home/hosting.outsur.cc/public_html --force --debug`
No, I haven’t found this method before, thank you.
So:
Here’s what I found.
The file is in the site directory:
But the page shows a 404 error:
http://hosting.outsur.cc/.well-known/acme-challenge/sPPP04HO_qiI3SW2yi3DVzbXqWUUCSitu53vdS8BOLc
Are we close to solving this mystical story?
upd:
There is no file in the site directory .htaccess
For the test, I uploaded 2 more files:
/public_html/.well-known/test.jpeg - 200 OK
/public_html/.well-known/acme-challenge/test.jpeg - 404 Error
So, there seems to be an error in the acme-challenge folder.
I deleted the folder manually.
Then I started issuing the certificate through the console again.
Now another error has occurred:
Some kind of problem with the domain www.hosting.outsur.cc :thinking:
Hell, that’s what happened in Cloudflare.
The www. domain was proxied :scream:
To make everything beautiful, I removed the site from the panel altogether and added it again.
Yes, SSL is ready.
Thanks gwnmikedus!
The code from the previous message allowed to debug.
