SSL Error After Certificate Renewal (Cloudflare + CyberPanel)
Subject: SSL Error After Certificate Renewal (Cloudflare + CyberPanel)
I am using a Hostinger VPS with CyberPanel as the control panel.
My domain is pointed and managed through Cloudflare.
The issue is the following:
  • The SSL certificate of one of my websites expired.
  • I renewed the SSL certificate via Cloudflare, where the domain is managed.
  • In CyberPanel, the SSL status shows as active/renewed.
  • However, the website still shows an SSL error in the browser and does not open securely.
What I have already checked:
  • DNS is correctly pointing through Cloudflare
  • SSL is enabled both in Cloudflare and in CyberPanel
  • The SSL error still persists across the entire website
I urgently need assistance to:
  • Identify the cause of the SSL conflict between Cloudflare and CyberPanel
  • Fix the issue so the website loads correctly over HTTPS without security warnings
Please help me verify:
  • Whether there is a conflict between Cloudflare SSL mode (Full / Full Strict) and the local SSL on CyberPanel
  • If the SSL certificate needs to be reinstalled or forced to renew on the server
  • If any additional configuration is required in CyberPanel or the website’s Virtual Host
I would appreciate your guidance to resolve this issue as soon as possible.
Thank you in advance for your support.
Best regards,
