Hopefully Everything is fine.
Recently I’ve Facing an Issue on the Latest Version on Cyberpanel.
Screenshot: https://i.postimg.cc/pLJgj38f/p.png
If I Add More then One Domains on Domain Alias
Both SSL Get Conflict or One Get Removed from each other.
Can got issue SSL for Two Domains
Error Screenshot: https://i.postimg.cc/T1nk6WJV/p.png
Please Tell Me How can solve this issue.
Thank You
Better create alias domain as child-domains then use vHost conf to point it to the document root of main domain.
Then issue SSL for each child-domain separately, that will be much better.
Better create alias domain as child-domains then use vHost conf to point it to the document root of main domain.Then issue SSL for each child-domain separately, that will be much better.
Thanks its Worked
Hi, sir can you send an image example of how to do this I am facing the same issue and unable to add SSL on alias domain?
Would you please explain how to do this, for the less technically saavy?
Directory of my Multisite network openlscheck.cf - /home/openlscheck.cf/public_html
vHost Conf openlscheck.cf shows -
docRoot $VH_ROOT/public_html
The first network site - site1.openlscheck.cf was created and mapped to openlscheck.ml and its works with domain alias.
Networksite was created on "domain1.openlschek.cf and was mapped to openlscheck.tk but gives SSL conflict, to resolve the same I have added the domain as a child domain instead of domain alias
openlscheck.tk has default path /home/openlscheck.cf/public_html/openlscheck.tk
vHost Conf (default) openlscheck.tk -
docRoot /home/openlscheck.cf/public_html/openlscheck.tk
when I changed vHost Conf to -
so that it will direct it to Multisite Network directory
Still in the list in Domains>List Domains the default path still shows
and not the /home/openlscheck.cf/public_html
Also openlscheck.tk is giving 404 error. Kindly guide me what exactly i should do to resolve this.
