OLS or Enterprise? OLS
CyberPanel 1.8.8 Fresh Install (not upgrade)
The following info is from my memory. Is there a log I can check?
Installing from official server or mirror server? official
Replace JS/CSS files to JS Delivr? no
Install Memcached extension for PHP? Yes
Install LiteSpeed Memcached? yes
Install Memcached? no
Install Redis extension for PHP? yes
Install Redis? yes
Problem:
Unable to obtain Let’s Encrypt SSL Cert for domain where Cloudflare provides authoritative nameserver services. Neither did CyberPanel create a self-signed cert as docs stated would happen if certbot failed. Error message: 283 Failed to obtain SSL for domain. [issueSSLForDomain] [404]
Certbot seems to do fine with cPanel brand hosted websites running LSWS Enterprise under same circumstances so suspect this is fixable.
Site has been “running” without SSL all along. Subject to other bug reports that is. So running means serving the two sample pages since we cannot add new blog posts and pages. Serving them from cache on a world-class web server. Hello World!
Attempting SSL cert after-the-fact received the same error. Weekly certbot limit is 5 if memory serves me correctly and this is new domain so limit is likely not the problem. Certainly at limit by now because kept pushing the button like a monkey. Mindful that one of the definitions of insanity is doing the same thing and expecting a different result. Hello World!
This is a test server for now so we can experiment as needed. If creating an A record for a subdomain gets us a fresh 5 count we’ll give that a shot. Will it?
