SSL Binding Conflicts
I’m using VPS with CentOS 7 and Cyberpanel Ver. 2.3
Actually, I have 3 domains named: abc.com, pqrs.com, and xyz.com from these 3 one of my domain named pqrs.com got expired because there’s no need for that but my databases of pqrs.com still on my VPS. Now the resultant for other 2 domains named abc.com and xyz.com subdomain named go.abc.com and goes.xyz.com’s SSL certificate shows in the name of pqrs.com when I’m using browsers to visit my website, a security risk message displayed and shows connection is not secure.
Recently, I have deleted my domain named pqrs.com from the Cyberpanel, but the problem is still present.
How to resolve this?
Hello @Emilia
Verify the virtual host configurations for your subdomains in CyberPanel to ensure they are not still referencing the expired domain’s certificate.
Please Review my httpd_config.conf :slight_smile:
# PLAIN TEXT CONFIGURATION FILE
#It not set, will use host name as serverName
serverName
user                             nobody
group                            nobody
priority                         0
autoRestart                      1
chrootPath                       /
enableChroot                     0
inMemBufSize                     60M
swappingDir                      /tmp/lshttpd/swap
autoFix503                       1
gracefulRestartTimeout           300
mime                             conf/mime.properties
showVersionNumber                0
adminEmails                      root@localhost
indexFiles                       index.html, index.php
disableWebAdmin                  0
errorlog logs/error.log {
        logLevel             DEBUG
        debugLevel           0
        rollingSize          10M
        enableStderrLog      1
accessLog logs/access.log {
        rollingSize          10M
        keepDays             30
        compressArchive      0
        logReferer           1
        logUserAgent         1
expires {
    enableExpires           1
    expiresByType           image/*=A604800,text/css=A604800,application/x-javascript=A604800,application/javascript=A604800,font/*=A604800$
tuning{
    maxConnections               10000
    maxSSLConnections            10000
    connTimeout                  300
    maxKeepAliveReq              10000
    smartKeepAlive               0
    keepAliveTimeout             5
    sndBufSize                   0
    rcvBufSize                   0
    gzipStaticCompressLevel	 6
    gzipMaxFileSize              10M
    eventDispatcher              best
    maxCachedFileSize            4096
    totalInMemCacheSize          20M
    maxMMapFileSize              256K
    totalMMapCacheSize           40M
    useSendfile                  1
    fileETag                     28
    SSLCryptoDevice              null
    maxReqURLLen                 32768
    maxReqHeaderSize             65536
    maxReqBodySize               2047M
    maxDynRespHeaderSize         32768
    maxDynRespSize               2047M
    enableGzipCompress           1
    enableBrCompress             4
    enableDynGzipCompress        1
    gzipCompressLevel            6
    brStaticCompressLevel        6
    compressibleTypes            default
    gzipAutoUpdateStatic         1
    gzipMinFileSize              300
    quicEnable                   1
    quicShmDir                   /dev/shm
accessDenyDir{
    dir                  /
    dir                  /etc/*
    dir                  /dev/*
    dir                  conf/*
    dir                  admin/conf/*
fileAccessControl{
    followSymbolLink                            1
    checkSymbolLink                             0
    requiredPermissionMask                      000
    restrictedPermissionMask                    000
perClientConnLimit{
    staticReqPerSec                          0
    dynReqPerSec                             0
    outBandwidth                             0
    inBandwidth                              0
    softLimit                                10000
    hardLimit                                10000
    gracePeriod                              15
    banPeriod                                300
CGIRLimit{
    maxCGIInstances                         20
    minUID                                  11
    minGID                                  10
    priority                                0
    CPUSoftLimit                            10
    CPUHardLimit                            50
    memSoftLimit                            1460M
    memHardLimit                            1470M
    procSoftLimit                           400
    procHardLimit                           450
accessControl{
	allow                                   ALL
        deny
extProcessor lsphp{
    type                            lsapi
    address                         uds://tmp/lshttpd/lsphp.sock
    maxConns                        10
    env                             PHP_LSAPI_CHILDREN=10
    env                             LSAPI_AVOID_FORK=200M
    initTimeout                     60
    retryTimeout                    0
    persistConn                     1
    pcKeepAliveTimeout
    respBuffer                      0
    autoStart                       1
    path                            $SERVER_ROOT/lsphp73/bin/lsphp
    backlog                         100
    instances                       1
    priority                        0
    memSoftLimit                    2047M
    memHardLimit                    2047M
    procSoftLimit                   1400
    procHardLimit                   1500
scriptHandler{
    add lsapi:lsphp  php
railsDefaults{
    binPath
    railsEnv                 1
    maxConns                 1
    env                      LSAPI_MAX_IDLE=60
    initTimeout              60
    retryTimeout             0
    pcKeepAliveTimeout       60
    respBuffer               0
    backlog                  50
    runOnStartUp             3
    extMaxIdleTime           300
    priority                 3
    memSoftLimit             2047M
    memHardLimit             2047M
    procSoftLimit            500
    procHardLimit            600
wsgiDefaults{
    binPath
    railsEnv                 1
    maxConns                 5
    initTimeout              60
    retryTimeout             0
    respBuffer               0
    backlog                  50
    runOnStartUp             3
    extMaxIdleTime           300
    priority                 3
    memSoftLimit             2047M
    memHardLimit             2047M
    procSoftLimit            500
    procHardLimit            600
nodeDefaults{
    binPath
    railsEnv                 1
    maxConns                 5
    initTimeout              60
    retryTimeout             0
    respBuffer               0
    backlog                  50
    runOnStartUp             3
    extMaxIdleTime           300
    priority                 3
    memSoftLimit             2047M
    memHardLimit             2047M
    procSoftLimit            500
    procHardLimit            600
virtualHost Example{
    vhRoot                   Example/
    allowSymbolLink          1
    enableScript             1
    restrained               1
    maxKeepAliveReq
    smartKeepAlive
    setUIDMode               0
    chrootMode               0
    configFile               conf/vhosts/Example/vhconf.conf
listener Default{
  map                     go.abc.com go.abc.com
  map                     goes.xyz.com goes.xyz.com
  map                     mail.abc.com mail.abc.com
  map                     abc.com abc.com
  map                     mail.xyz.com mail.xyz.com
  map                     xyz.com xyz.com
  map                     mail.pqrs.com mail.pqrs.com
  map                     pqrs.com pqrs.com
    address                  *:80
    secure                   0
vhTemplate centralConfigLog{
    templateFile             conf/templates/ccl.conf
    listeners                Default
vhTemplate EasyRailsWithSuEXEC{
    templateFile             conf/templates/rails.conf
    listeners                Default
module cache {
    ls_enabled          1
    checkPrivateCache   1
    checkPublicCache    1
    maxCacheObjSize     10000000
    maxStaleAge         200
    qsCache             1
    reqCookieCache	1
    respCookieCache     1
    ignoreReqCacheCtrl  1
    ignoreRespCacheCtrl 0
    enableCache         0
    expireInSeconds     3600
    enablePrivateCache  0
    privateExpireInSeconds 3600
virtualHost pqrs.com {
  vhRoot                  /home/$VH_NAME
  configFile              $SERVER_ROOT/conf/vhosts/$VH_NAME/vhost.conf
  allowSymbolLink         1
  enableScript            1
  restrained              1
listener SSL {
  map                     abc.com abc.com
  map                     xyz.com xyz.com
  address                 *:443
  secure                  1
  keyFile                  /etc/letsencrypt/live/pqrs.com/privkey.pem
  certFile                 /etc/letsencrypt/live/pqrs.com/fullchain.pem
  certChain               1
  sslProtocol             24
  ciphers                 EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH:ECDHE-RSA-AES128-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-RSA$
  enableECDHE             1
  renegProtection         1
  sslSessionCache         1
  enableSpdy              15
  enableStapling           1
  ocspRespMaxAge           86400
virtualHost mail.pqrs.com {
  vhRoot                  /home/pqrs.com
  allowSymbolLink         1
  enableScript            1
  restrained              1
virtualHost xyz.com {
  allowSymbolLink         1
  enableScript            1
  restrained              1
virtualHost mail.xyz.com {
  vhRoot                  /home/xyz.com
  allowSymbolLink         1
  enableScript            1
  restrained              1
virtualHost abc.com {
  allowSymbolLink         1
  enableScript            1
  restrained              1
virtualHost mail.abc.com {
  vhRoot                  /home/abc.com
  allowSymbolLink         1
  enableScript            1
  restrained              1
virtualHost goes.xyz.com {
  allowSymbolLink         1
  enableScript            1
  restrained              1
virtualHost go.abc.com {
  allowSymbolLink         1
  enableScript            1
  restrained              1
listener SSL IPv6 {
  address                 [ANY]:443
  secure                  1
  certChain               1
  sslProtocol             24
  enableECDHE             1
  renegProtection         1
  sslSessionCache         1
  enableSpdy              15
  enableStapling           1
Please advice me where I can make changes.
Thanks
Without digging deep into this issue first of all I will suggest you to move all of your sites as soon as possible away from centos 7.
Some interesting thing happened:
  1. When I can set abc.com as SSL Listener ( IPv4 & IPv6), then xyz.com work fine. While abc.com shows 404 error.
  2. When I can set xyz.com as SSL Listener ( IPv4 & IPv6), then abc.com work fine. While xyz.com shows 404 errors.
  3. When I set anyone either abc.com or xyz.com as SSL Listener ( IPv4 & IPv6) and Restart OpenLiteSpeed, then for 10-15 min both domains and subdomain’s works fine.
  4. How can?
Thanks
