SSH permit root login Disabled issue for Cyberpanel
Hi
I accidentally
disabled SSH Permit root login I can’t login in any way now and root user can’t login with Putty software I also don’t have ssh key how to fix it I want help from everyone
try login with your sudo user
or you go to cyberpanel and disable that? (never try this)
Cyber ​​panel is not going to login in any way. Login page is not opening
have you try this ?
