I installed new cyber panel because of previous problems. Everything is fine now thanks for replies.
How can I connect SSH with root. Server = Google Cloud But I don’t want to connect on google cloud. I just want to connect with directly cyberpanel root
Not sure if I understand your question, do you want to access your Google Cloud VPS from ssh client such as putty with root username and not the Google Cloud Console?
nearly…
If there is a chance to setup a user for ssh from cyberpanel it will be best.
They disable SSH root login, as well as password authentication. You can set up key-based authentication using their guide.
But its nothing that CyberPanel can do about it.
