Try to setup Database Privileges for WHMCS but cant find any settings ?
yea this is junk have dig in phpmyadmin just set privileges .
not running right php i set it to
sql not using SSL ?
cant run yum update do to cyberpanel take over of mirrors
PHP Session Support
PHP session support is enabled.
Session autostart is disabled.
The PHP session save path /var/lib/lsphp/session/lsphp74 is not writable. Please investigate the session.save_path PHP setting or contact your system administrator
