Dear Cyberpanel Team
Let me introduce myself, I’m Ahnaf Fauzan and still studying at a vocational high school in Indonesia.
I was very interested in cyberpanel and then installed it on my Google Cloud, but I encountered several obstacles when using it.
- ssl cyberpanel gets a warning from the browser.
but it can still be overcome: How to setup Custom SSL with CyberPanel! - #2 by ZakiMDH - Blog Posts - CyberPanel Community - at first I didn’t know that I had to use the command “sudo su -” not just “sudo su”.
but this is only a trivial matter - I do not know what ports are needed.
like I just found out that TCP 53 port must be opened when I want to use DNS service - Ubuntu OS has been supported but Debian has not.
actually this is not a problem - there are only fix permissions.
hopefully in the future cyberpanel can set permissions such as chmod 777, chmod 755, etc - install php extension does not work.
some php extensions must be installed manually like ioncube =
https://forums.cyberpanel.net/discussion/228/install-ioncube-loader-on-openlitespeed - unable to install the docker.
almost like ioncube at number 7, but this time I haven’t got the solution - cyberpanel plugin.
I don’t know the plugin function in cyberpanel, even I don’t know what plugins are available - ssh and web terminal does not work.
I haven’t found a solution yet, but one of the moderators at Discord says it’s because I use Google Cloud - I installed the ekattor but got an error.
I am not sure where the error is, but I have tried installing the ekattor on shared hosting and that is normal
sorry if my English is bad.
honestly I really like cyberpanel, I really hope cyberpanel will be better.
I am very grateful to the cyberpanel team:)
- I use VM on Google Cloud with Centos 8 and Python3
