Snappymail problem
My Snappymail after
  1. Import Accounts
  2. Unzip vmail.tar.gz on /home/vmail
  3. Access Snappymail account
    Show this error below
check whether your postfix and dovecot is running or installed… Since ghettoforge repo dead forever (check their domain) - postfix and dovecot update and installation were stop especially is you runs Almalinux…
Both are running.but show running in other domain instead correct domain,
Solved, add this line: maildir_broken_filename_sizes=yes
to this file config: /etc/dovecot/dovecot.conf
restart postfix and dovecot with: systemctl restart dovecot postfix, and vuala
