I have been able to log in to the admin panel some time ago, but when I try now, I am not able to log in.
Also, I have searched the forum and have tried some of the suggestions, but so far, no luck.
Any ideas?
Any ideas?
Hello @Oceanwatcher
Using ssh terminal log into your server and run the command
nano /usr/local/lscp/cyberpanel/rainloop/data/_data_/_default_/admin_password.txt || vi /usr/local/lscp/cyberpanel/rainloop/data/_data_/_default_/admin_password.txt
Thats where you admin password is. Use it to log in to snappymail admin panel
Thank you for responding. Would be nice if it worked. I assume the text in that file is the password, as there is nothing else that a short text.
I am on Ubuntu if it makes any difference.
A few months ago, I logged in to the admin panel and I changed the login. I do have that login as it is stored in
/usr/local/lscp/cyberpanel/rainloop/data/data/default/configs/application.ini
But that one is not working either.
Have you tried to reset the password SnappyMail admin password reset - #2 by seanfitz09
Yes. Tried it and nothing happened. I commented out the old user and password. Rebooted the whole server. But nothing new. The user and pass is still commented out.
This should remain as is. For some reason you have to try everal times until it goes through
What do you mean I should try several times? Obviously there is a bug here somewhere…
Is snappymail a service that can be retarted, or just a php (or similar) script?
Stop interfering with the application.ini. SnappyMail creates a new admin password for you when application.ini has empty admin_password entry.
Also your issue has nothing to do with cyberpanel so if you still cannot get this working I would recommend you open an issue here Issues · the-djmaze/snappymail · GitHub
Snappymail does NOT generate a new admin password when the old is commented out. I am not sure what you mean by stop interfering. I am following the instructions about this as well as I can.
You are now saying that admin_password should be empty. That is not what the instructions say. There, it says it should be commented out. Which one is correct?
Which instructions are you following ?
For anyone else running into the issue of the admin password not being regenerated. Make sure you’re logging into the admin login page, that’s the one yourdomain.com:8090/?admin
I was trying to login to the user one and it wasn’t working for me.
