please you guys help me My ssl certificate was working fine but i clicked on renew ssl certificate, since then ssl is not working please help me my site is down very big reuqest to you.
Do check if your site domain is correctly pointing to your server IP. Also make sure if you are using Cloudflare DNS, then you need to disable orange cloud proxy when renewing or issuing SSL.
