Remote Transfer Error - Emergency Help
How to fix it gives the following error when connected to the server to make remote transfer?
Not able to fetch version of remote server. Error Message: HTTPSConnectionPool(host=‘İPADRESS’, port=8090): Max retries exceeded with url: /api/cyberPanelVersion (Caused by SSLError(SSLError(“bad handshake: Error([(‘SSL routines’, ‘ssl3_get_record’, ‘wrong version number’)],)”,),))
Do you have active SSL on both sides?
@CyberPanel Yes there is
Alright, please contact us via helpdesk.
