Hello, I transferred the website running on cpanel to the cyberpanel server, but after solving the recaptcha on the site, I get a “Failed captcha” error. What could be the cause of this problem? There was no problem with the old server.
Disable CSF and Modsecurity and try again if those blocking it
Did you tried to disable and then activate and check
