I have multiple domains on a cyberpanel and I would like to have clients access rainloop by typing in mail.domain.com
Is that possible?
create a sub domain , install a rainloop there should do it
Thank you,
Can’t I point the domain to point to the already-existing rainloop installation on port 8090?
technically yes, but that will involves a reverse proxy and URL manipulation , too much complication and overhead , install a rainloop on the sub-domain will be much easier and simpler.
Thank you.
@qtwrk do we have to add every domain to new installed rainloop or are there any easy way to link it ? Thanks a lot in advance!
you can create a shell script to deploy it I guess
