info@abcd.com>, relay=dovecot, delay=0.1, delays=0.06/0.01/0/0.03, dsn=5.1.1, status=bounced (user unknown. Command output: lda(info@abcd.com): Error: net_connect_unix(/var/run/dovecot/stats-writer) failed: Permission denied )
info@abcd.com>, relay=dovecot, delay=0.12, delays=0.08/0.01/0/0.03, dsn=5.1.1, status=bounced (user unknown. Command output: lda(info@abcd.com): Error: net_connect_unix(/var/run/dovecot/stats-writer) failed: Permission denied )
design@xyz.com>, relay=dovecot, delay=0.12, delays=0.08/0.01/0/0.03, dsn=5.1.1, status=bounced (user unknown. Command output: lda(design@xyz.com): Error: net_connect_unix(/var/run/dovecot/stats-writer) failed: Permission denied )
I have same error, and also i can’t login to webmail
What you did and is this for all users or some? Please check the postfix service if running or not.
please try restart dovecot ?
postfix is running, and for all users.
