hi i wanted to know how i can renew the SSL certificate for the panel that I can access from the IP
I don’t want to add it to a domain I just want to use cyber panel from the IP
Re-issue hostname SSL for panel domain
ive said im using the ip not the domain
I want to renew the SSL for the IP not domain could you say how to do that?
You cant add SSL for IP address.
