If you’ve been grinding Monopoly Go for a while, you already know that Partner Events can make or break your progress. And when the Turkey Trot event rolls around, it becomes one of the best opportunities to rack up huge amounts of dice, sticker packs, cash, and partner event currency. As someone who’s been through every major event in this game since launch, Turkey Trot is easily one of the most generous. If you’re trying to push leaderboard standings or complete your partner builds faster, this event is a must-play. And if you’re ever short on rolls, many players turn to PVPBank to safely buy Monopoly Go dice without slowing down during limited-time events.
The 2025 Turkey Trot is basically a race to collect points by landing on Chance, Tax, or Utility tiles. That’s it. Simple, fast, and super rewarding. For every Chance or Utility tile you land on, you get +2 points, and landing on Tax gives +3. Rack up enough event points and you’ll grab over twenty thousand dice rolls in total, not to mention sticker packs, cash, boosts, and partner currency. If you’re aiming to max out all 62 reward tiers, the earlier you start the better.
How the Turkey Trot Event Works
Turkey Trot is one of those Monopoly Go events that reward consistent rolling more than anything else. There’s no complicated mini-game, no special board, nothing fancy. It’s all about landing on those three specific tiles. With a good multiplier, you can clear big chunks of the rewards list in one session. Veteran players know the trick: save your high rolls or use boosts during periods when your board layout favors tile cycling. This way, you dramatically increase your landing rate and point efficiency.
And here’s the thing a lot of newer players miss: Turkey Trot isn’t just for dice. The partner event currency sprinkled throughout the reward tiers is often the bottleneck in current partner events. So even if you’re fully stocked on rolls, this event is still worth your time.
All Monopoly Go Turkey Trot Rewards
Here’s a full breakdown of the Turkey Trot reward tiers and what you’ll earn at each stage. If your goal is maximizing dice, the biggest jackpots are at levels 25, 35, 43, 48, 56, and the final massive reward at level 62.
Levels 1–10: Early Progress Boost
The first ten tiers give partner currency, small dice packs (25, 45, 55 rolls), sticker packs, and a big jump at level 10 with 160 dice. These early tiers are super easy to clear, even with low multipliers. Most experienced players burn through the first ten within a few minutes.
Levels 11–20: First Major Milestones
You’ll grab more partner currency, cash rewards, boosts, and a huge 615 dice at level 20. This is where you start feeling the momentum of the event.
Levels 21–30: Midgame Ramp-Up
Here the tier prices go up, but so do the rewards. You’ll get bigger sticker packs, 100+ dice drops, and the standout 1,000 dice at level 25. If you want to finish the event, this is the point where you decide whether to commit or slow down.
Levels 31–43: Heavy Dice Tiers
These levels include the 1,200 dice drop at tier 35 and 1,550 dice at tier 43. Partner event currency pops up frequently too, making this section valuable for players grinding current partner builds.
Levels 44–56: Premium Rewards Section
This stretch includes some of the best boost rewards and the massive 1,850 dice bonus at level 48. But nothing compares to tier 56, which grants 2,500 dice. If you’re farming Sticker Boom or Golden Blitz, this is prime resource-stacking territory.
Levels 57–62: The Final Push
These last few tiers ramp costs to extremes, but they end with the biggest reward in the entire event: a colossal 5,550 dice at tier 62. If you manage to finish Turkey Trot before it expires, you’ll walk away with more rolls than most weekly events combined.
Tips for Maximizing Turkey Trot Rewards
Veteran players swear by a few core strategies:
Time multipliers smartly:
Never blast through your x50 or x100 on a cold board. Roll a few singles to check landing trends.
Save boosts for heavy play sessions:
Rent, Cash Grab, or High Roller boosts pair extremely well with Turkey Trot.
Play during event overlap windows:
If Turkey Trot overlaps with tournaments or quick wins, you can hit multiple progression systems at once.
Keep dice inventory balanced:
Avoid dropping below a few hundred rolls unless you can restock quickly. Running dry halfway through a limited-time event is painful.
Final Thoughts
The Monopoly Go Turkey Trot event is easily one of the most rewarding partner-support events of the year. Whether you’re chasing the final 5,550-dice mega reward or just trying to pick up partner currency along the way, there’s something here for every type of player. And if you need an extra push to finish strong, many players trust PVPBank to buy Monopoly Go dice safely during high-stakes events.
