CheckTLS Confidence Factor for “Info@buyitbest.co.za”: 108 of 114 (94%, 124 max)
| MX Server |
Pref |
Answer |
Connect |
HELO |
TLS |
Cert |
Secure |
From |
MTASTS |
DANE |
Score |
| _dc-mx.ab9ccac02153.buyitbest.co.za |
| [129.151.163.228:25] |
0 |
OK |
| (240ms) |
OK |
| (957ms) |
OK |
| (240ms) |
OK |
| (240ms) |
FAIL |
OK |
| (2,408ms) |
OK |
| (241ms) |
not tested |
not tested |
108.00 |
| Average |
100% |
100% |
100% |
100% |
0% |
100% |
100% |
108 |
Scan down DETAIL output below for info on errors and warnings.
Checking Info@buyitbest.co.za from www12-azure.checktls.com(V03.66.05) at 2022-05-23T01:25:02Z:
| seconds |
lookup |
result |
| [000.000] |
DNS LOOKUPS |
| [000.001] |
SEARCHLIST |
104.131.108.216,134.209.169.224,1.1.1.1,8.8.8.8,67.207.67.3 |
| [000.018] |
MX |
(0) _dc-mx.ab9ccac02153.buyitbest.co.za |
| [000.035] |
MX:A–>_dc-mx.ab9ccac02153.buyitbest.co.za |
129.151.163.228 |
| seconds |
test stage and result |
| [000.000] |
Trying TLS on _dc-mx.ab9ccac02153.buyitbest.co.za[129.151.163.228:25] (0) |
| [000.240] |
Server answered |
| [001.197] |
220 buyitbest.co.za ESMTP Postfix |
| [001.197] |
We are allowed to connect |
| [001.197] |
EHLO www12-azure.checktls.com
| [001.436] |
250-buyitbest.co.za |
| 250-PIPELINING |
| 250-SIZE 30720000 |
| 250-ETRN |
| 250-STARTTLS |
| 250-AUTH PLAIN |
| 250-AUTH=PLAIN |
| 250-ENHANCEDSTATUSCODES |
| 250-8BITMIME |
| 250-DSN |
| 250 CHUNKING |
| [001.437] |
We can use this server |
| [001.437] |
TLS is an option on this server |
| [001.437] |
STARTTLS |
| [001.676] |
220 2.0.0 Ready to start TLS |
| [001.677] |
STARTTLS command works on this server |
| [001.930] |
Connection converted to SSL |
SSLVersion in use: TLSv1_3 |
Cipher in use: TLS_AES_256_GCM_SHA384 |
Perfect Forward Secrecy: yes |
Session Algorithm in use: Curve X25519 DHE(253 bits) |
Certificate #1 of 1 (sent by MX): |
Cert VALIDATION ERROR(S): self signed certificate |
So email is encrypted but the recipient domain is not verified |
Cert Hostname DOES NOT VERIFY (_dc-mx.ab9ccac02153.buyitbest.co.za != buyitbest.co.za) |
So email is encrypted but the host is not verified |
Not Valid Before: May 23 01:24:48 2022 GMT |
Not Valid After: May 20 01:24:48 2032 GMT |
subject: /C=US/ST=Denial/L=Springfield/O=Dis/CN=buyitbest.co.za |
issuer: /C=US/ST=Denial/L=Springfield/O=Dis/CN=buyitbest.co.za |
| [001.933] |
| [002.408] |
| 250-PIPELINING |
| 250-SIZE 30720000 |
| 250-ETRN |
| 250-AUTH PLAIN |
| 250-AUTH=PLAIN |
| 250-8BITMIME |
| 250-DSN |
| 250 CHUNKING |
| [002.408] |
TLS successfully started on this server |
| [002.409] |
MAIL FROM:test@checktls.com
| [002.649] |
250 2.1.0 Ok |
| [002.650] |
Sender is OK |
| [002.650] |
QUIT |
| [002.893] |
221 2.0.0 Bye |
