I have installed CyberPanel on Amazon Lightsail (4 GB RAM, 2 vCPUs). All the necessary ports are open from Amazon and CyberPanel. I have installed WP. I using CloudFlare DNS, but I can’t access to site using Domain.
When I setup DNS and CDN on CloudFlare site is not accessible but returning to Error 502 (Bad gateway). Firewall Screenshots: https://i.imgur.com/AHJSDXh.jpg
I figured out the Problem, It’s SSL issue, when I enabled Full SSL on CloudFlare, It’s returning to 502 Error page, because SSL is not installed on Origin Sever.
But I installed SSL using CyberPanel, I also reissued few times for fixing the Issue. That means CyberPanel actually not installing SSL but showing the Success message. It’s a bugs of CyberPanel that it’s showing success message without installing SSL.
I figured out the Problem, It's SSL issue, when I enabled Full SSL on CloudFlare, It's returning to 502 Error page, because SSL is not installed on Origin Sever.
How can I fix this Issue?
What does CyberPanel main log file says when you try to issue SSL?
