I’m facing an issue with hostname SSL since I upgraded to the latest version. (Everything works fine before)
The same issue exists for other domains also. Here are some server logs.
Domains are http://verticalcloud.co and http://lilpaw.shop
[10.15.2022_00-00-04] Checking SSL for portal.keephiring.net.
[10.15.2022_00-00-04] SSL exists for portal.keephiring.net. Checking if SSL will expire in 15 days..
[10.15.2022_00-00-04] SSL exists for portal.keephiring.net and is not ready to renew, skipping..
[10.15.2022_00-00-04] Checking SSL for dial.1477.store.
[10.15.2022_00-00-04] SSL exists for dial.1477.store. Checking if SSL will expire in 15 days..
[10.15.2022_00-00-04] SSL exists for dial.1477.store and is not ready to renew, skipping..
[10.15.2022_00-00-04] Checking SSL for sms.easybill.shop.
[10.15.2022_00-00-04] SSL exists for sms.easybill.shop. Checking if SSL will expire in 15 days..
[10.15.2022_00-00-04] SSL exists for sms.easybill.shop and is not ready to renew, skipping..
[10.15.2022_02-54-02] 'list' object has no attribute 'find'
[10.15.2022_02-56-24] 'list' object has no attribute 'find'
[10.15.2022_02-57-41] Request body exceeded settings.DATA_UPLOAD_MAX_MEMORY_SIZE.
[10.15.2022_02-57-53] 'list' object has no attribute 'find'
[10.15.2022_03-10-28] Status Code: Unknown for: http://www.lilpaw.shop/.well-known/acme-challenge/lilpaw.shop. Error: Exceeded 30 redirects.
[10.15.2022_03-10-28] Status Code: Unkown for: http://lilpaw.shop/.well-known/acme-challenge/lilpaw.shop. Error: Exceeded 30 redirects.
[10.15.2022_03-10-35] /root/.acme.sh/acme.sh --issue -d lilpaw.shop -d www.lilpaw.shop --cert-file /etc/letsencrypt/live/lilpaw.shop/cert.pem --key-file /etc/letsencrypt/live/lilpaw.shop/privkey.pem --fullchain-file /etc/letsencrypt/live/lilpaw.shop/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
[10.15.2022_03-10-43] Failed to obtain SSL for: lilpaw.shop and: www.lilpaw.shop
[10.15.2022_03-10-43] Trying to obtain SSL for: lilpaw.shop
[10.15.2022_03-10-49] Failed to obtain SSL, issuing self-signed SSL for: lilpaw.shop
[10.15.2022_03-10-49] Self signed SSL issued for lilpaw.shop.
[10.15.2022_03-16-28] Status Code: Unknown for: http://www.lilpaw.shop/.well-known/acme-challenge/lilpaw.shop. Error: Exceeded 30 redirects.
[10.15.2022_03-16-28] Status Code: Unkown for: http://lilpaw.shop/.well-known/acme-challenge/lilpaw.shop. Error: Exceeded 30 redirects.
[10.15.2022_03-16-39] /root/.acme.sh/acme.sh --issue -d lilpaw.shop -d www.lilpaw.shop --cert-file /etc/letsencrypt/live/lilpaw.shop/cert.pem --key-file /etc/letsencrypt/live/lilpaw.shop/privkey.pem --fullchain-file /etc/letsencrypt/live/lilpaw.shop/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
[10.15.2022_03-16-46] Failed to obtain SSL for: lilpaw.shop and: www.lilpaw.shop
[10.15.2022_03-16-46] Trying to obtain SSL for: lilpaw.shop
[10.15.2022_03-16-52] Failed to obtain SSL, issuing self-signed SSL for: lilpaw.shop
[10.15.2022_03-16-53] Self signed SSL issued for lilpaw.shop.
[10.15.2022_03-23-49] Status Code: Unknown for: http://www.lilpaw.shop/.well-known/acme-challenge/lilpaw.shop. Error: Exceeded 30 redirects.
[10.15.2022_03-23-49] Status Code: Unkown for: http://lilpaw.shop/.well-known/acme-challenge/lilpaw.shop. Error: Exceeded 30 redirects.
[10.15.2022_03-23-56] /root/.acme.sh/acme.sh --issue -d lilpaw.shop -d www.lilpaw.shop --cert-file /etc/letsencrypt/live/lilpaw.shop/cert.pem --key-file /etc/letsencrypt/live/lilpaw.shop/privkey.pem --fullchain-file /etc/letsencrypt/live/lilpaw.shop/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
[10.15.2022_03-24-04] Failed to obtain SSL for: lilpaw.shop and: www.lilpaw.shop
[10.15.2022_03-24-04] Trying to obtain SSL for: lilpaw.shop
[10.15.2022_03-24-06] Failed to obtain SSL, issuing self-signed SSL for: lilpaw.shop
[10.15.2022_03-24-07] Self signed SSL issued for lilpaw.shop.
[10.15.2022_03-25-05] Status Code: Unknown for: http://www.verticalcloud.co/.well-known/acme-challenge/verticalcloud.co. Error: Exceeded 30 redirects.
[10.15.2022_03-25-06] Status Code: Unkown for: http://verticalcloud.co/.well-known/acme-challenge/verticalcloud.co. Error: Exceeded 30 redirects.
[10.15.2022_03-25-18] /root/.acme.sh/acme.sh --issue -d verticalcloud.co -d www.verticalcloud.co --cert-file /etc/letsencrypt/live/verticalcloud.co/cert.pem --key-file /etc/letsencrypt/live/verticalcloud.co/privkey.pem --fullchain-file /etc/letsencrypt/live/verticalcloud.co/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
[10.15.2022_03-25-25] Failed to obtain SSL for: verticalcloud.co and: www.verticalcloud.co
[10.15.2022_03-25-25] Trying to obtain SSL for: verticalcloud.co
[10.15.2022_03-25-32] Failed to obtain SSL, issuing self-signed SSL for: verticalcloud.co
[10.15.2022_03-25-32] {'[email protected]': (550, b'5.1.1 <[email protected]>: Recipient address rejected: User unknown in virtual mailbox table')}
[10.15.2022_03-25-32] Self signed SSL issued for verticalcloud.co.
[10.15.2022_03-33-09] Status Code: Unknown for: http://www.verticalcloud.co/.well-known/acme-challenge/verticalcloud.co. Error: Exceeded 30 redirects.
[10.15.2022_03-33-09] Status Code: Unkown for: http://verticalcloud.co/.well-known/acme-challenge/verticalcloud.co. Error: Exceeded 30 redirects.
[10.15.2022_03-33-14] /root/.acme.sh/acme.sh --issue -d verticalcloud.co -d www.verticalcloud.co --cert-file /etc/letsencrypt/live/verticalcloud.co/cert.pem --key-file /etc/letsencrypt/live/verticalcloud.co/privkey.pem --fullchain-file /etc/letsencrypt/live/verticalcloud.co/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
[10.15.2022_03-33-22] Failed to obtain SSL for: verticalcloud.co and: www.verticalcloud.co
[10.15.2022_03-33-22] Trying to obtain SSL for: verticalcloud.co
[10.15.2022_03-33-28] Failed to obtain SSL, issuing self-signed SSL for: verticalcloud.co
[10.15.2022_03-33-28] {'[email protected]': (550, b'5.1.1 <[email protected]>: Recipient address rejected: User unknown in virtual mailbox table')}
[10.15.2022_03-33-28] Self signed SSL issued for verticalcloud.co.
As far as my understanding, there is no problem with DNS or NS because everything worked fine before. Also, for some domains, SSL is working fine.
