Hi, I don’t know where to categorized this post but I encountered an error.
I am trying to set up a smtp server so far it works fine but there is a slight problem.
Postfix seems to using a wrong cert for my mail server.
I already tried issuing a SSL (mail server ssl) for my mail.tinydes.top and I also add a SSL for web but is seems like it is not working properly.
This is the error that comes up whenever I test the CERT.
Cert VALIDATION ERROR(S): self signed certificate
So email is encrypted but the recipient domain is not verified
Cert Hostname DOES NOT VERIFY (mail.tinydesk.top != www.example.com)
So email is encrypted but the host is not verified
if you do a letsencrypt certificate request and have used up your 5 duplicate requests (ie requested ssl certificate more that 5 times) the certificate created is created for example.com. Cyberpanel does not reflect the error generated by lets encrypt and tells you that certificate issue was successful. All you need to do is wait 7 days for the block at letsencrypt to clear and try again.
