Hi there,
CHANGE PHP VERSION
I am trying to change the PHP version on a website to v8.0 using the Change PHP tool. It says it’s changed, but it continues to use version 7.4.25.
After leaving the “manage website” page for that site, and returning, it has 8.0 selected in the “Change PHP” tool. If I hit the change button again, it outputs, “Failed to change PHP version. Error message:”, with no actual error message.
Do you have any suggestions?
EDIT PHP CONFIGURATION
I also notice that if I try to use the Edit PHP Configuration tool, when I select php v8.0, CP shows this error, “Error message: local variable ‘post_max_size’ referenced before assignment”. No configuration options display. Just that error.
Why is that?
