2023-03-02 11:05:40.363358 [NOTICE] [958633] Server restart request from admin interface!
2023-03-02 11:05:40.363694 [NOTICE] [958635] Start shutting down gracefully …
2023-03-02 11:05:40.363769 [NOTICE] [958635] Event-loop lingering start.
2023-03-02 11:05:40.363881 [NOTICE] [958636] Start shutting down gracefully …
2023-03-02 11:05:40.363922 [NOTICE] [958636] Event-loop lingering start.
2023-03-02 11:05:40.365435 [NOTICE] [958633] Forked [958936] for graceful restart.
2023-03-02 11:05:40.365538 [NOTICE] [958633] Start passing listener sockets through forked child [958936].
2023-03-02 11:05:40.365589 [INFO] [958936] [UDP :7080] pass listener, copy fd 22 to 1011.
2023-03-02 11:05:40.365617 [INFO] [958936] [:7080] Pass listener, copy fd 18 to 1010.
2023-03-02 11:05:40.365628 [INFO] [958936] [UDP [::]:443], SO_REUSEPORT #1, pass listener copy fd 17 to 1009.
2023-03-02 11:05:40.365638 [INFO] [958936] [UDP [::]:443], SO_REUSEPORT #2, pass listener copy fd 16 to 1008.
2023-03-02 11:05:40.365648 [INFO] [958936] [TCP [::]:443], SO_REUSEPORT #1, pass listener copy fd 15 to 1007.
2023-03-02 11:05:40.365657 [INFO] [958936] [TCP [::]:443], SO_REUSEPORT #2, pass listener copy fd 14 to 1006.
2023-03-02 11:05:40.365667 [INFO] [958936] [UDP *:443], SO_REUSEPORT #1, pass listener copy fd 13 to 1005.
2023-03-02 11:05:40.365676 [INFO] [958936] [UDP *:443], SO_REUSEPORT #2, pass listener copy fd 12 to 1004.
2023-03-02 11:05:40.365685 [INFO] [958936] [TCP *:443], SO_REUSEPORT #1, pass listener copy fd 11 to 1003.
2023-03-02 11:05:40.365694 [INFO] [958936] [TCP *:443], SO_REUSEPORT #2, pass listener copy fd 10 to 1002.
2023-03-02 11:05:40.365703 [INFO] [958936] [TCP :80], SO_REUSEPORT #1, pass listener copy fd 9 to 1001.
2023-03-02 11:05:40.365712 [INFO] [958936] [TCP :80], SO_REUSEPORT #2, pass listener copy fd 8 to 1000.
2023-03-02 11:05:40.365738 [NOTICE] [958936] Starting new instance: execute ‘/usr/local/lsws/bin/litespeed’.
2023-03-02 11:05:40.397025 [INFO] [config:server:basics] httpdWorkers: 2, Num of Processors: 2
2023-03-02 11:05:40.397082 [INFO] [config:server:basics] enableLVE: 0
2023-03-02 11:05:40.397093 [INFO] [config:server:basics] bubbleWrap: 0, cmd: ‘(null)’
2023-03-02 11:05:40.404955 [INFO] [PlainConf] [httpServerConfig:] start parsing file /usr/local/lsws/conf/httpd_config.conf
2023-03-02 11:05:40.404991 [INFO] [PlainConf] [module:cache] RCS checkin config file /usr/local/lsws/conf/httpd_config.conf0 OK.
2023-03-02 11:05:40.405002 [INFO] [PlainConf] [module:cache] Finished parsing file /usr/local/lsws/conf/httpd_config.conf
2023-03-02 11:05:40.405014 [WARN] [PlainConf] [module:cache] parseFile find ‘{’ and ‘}’ do not match in the end of file /usr/local/lsws/conf/httpd_config.conf, rootTag httpServerConfig.
2023-03-02 11:05:40.405025 [INFO] [PlainConf] [module:cache] module [cache] add param [storagepath $SERVER_ROOT/cachedata]
2023-03-02 11:05:40.405035 [INFO] [PlainConf] [module:cache] module [cache] add param [checkprivatecache 1]
2023-03-02 11:05:40.405046 [INFO] [PlainConf] [module:cache] module [cache] add param [checkpubliccache 1]
2023-03-02 11:05:40.405053 [INFO] [PlainConf] [module:cache] module [cache] add param [maxcacheobjsize 10000000]
2023-03-02 11:05:40.405060 [INFO] [PlainConf] [module:cache] module [cache] add param [maxstaleage 200]
2023-03-02 11:05:40.405067 [INFO] [PlainConf] [module:cache] module [cache] add param [qscache 1]
2023-03-02 11:05:40.405074 [INFO] [PlainConf] [module:cache] module [cache] add param [reqcookiecache 1]
2023-03-02 11:05:40.405080 [INFO] [PlainConf] [module:cache] module [cache] add param [respcookiecache 1]
2023-03-02 11:05:40.405102 [INFO] [PlainConf] [module:cache] module [cache] add param [ignorereqcachectrl 1]
2023-03-02 11:05:40.405110 [INFO] [PlainConf] [module:cache] module [cache] add param [ignorerespcachectrl 0]
2023-03-02 11:05:40.405117 [INFO] [PlainConf] [module:cache] module [cache] add param [enablecache 0]
2023-03-02 11:05:40.405123 [INFO] [PlainConf] [module:cache] module [cache] add param [expireinseconds 3600]
2023-03-02 11:05:40.405130 [INFO] [PlainConf] [module:cache] module [cache] add param [enableprivatecache 0]
2023-03-02 11:05:40.405137 [INFO] [PlainConf] [module:cache] module [cache] add param [privateexpireinseconds 3600]
2023-03-02 11:05:40.405143 [INFO] [PlainConf] [module:cache] module [mod_security] add param [modsecurity on]
2023-03-02 11:05:40.405150 [INFO] [PlainConf] [module:cache] module [mod_security] add param [modsecurity_rules ] 2023-03-02 11:05:40.405157 [INFO] [PlainConf] [module:cache] module [mod_security] add param [secdebugloglevel 0] 2023-03-02 11:05:40.405163 [INFO] [PlainConf] [module:cache] module [mod_security] add param [secdebuglog /usr/local/lsws/logs/modsec.log] 2023-03-02 11:05:40.405170 [INFO] [PlainConf] [module:cache] module [mod_security] add param [secauditengine on] 2023-03-02 11:05:40.405177 [INFO] [PlainConf] [module:cache] module [mod_security] add param [secauditlogrelevantstatus "^(?:5|4(?!04))"] 2023-03-02 11:05:40.405183 [INFO] [PlainConf] [module:cache] module [mod_security] add param [secauditlogparts AFH] 2023-03-02 11:05:40.405256 [INFO] [PlainConf] [module:cache] module [mod_security] add param [secauditlogtype Serial] 2023-03-02 11:05:40.405264 [INFO] [PlainConf] [module:cache] module [mod_security] add param [secauditlog /usr/local/lsws/logs/auditmodsec.log] 2023-03-02 11:05:40.405271 [INFO] [PlainConf] [module:cache] module [mod_security] add param [secruleengine On] 2023-03-02 11:05:40.405278 [INFO] [PlainConf] [module:cache] module [mod_security] add param [
2023-03-02 11:05:40.405285 [INFO] [PlainConf] [module:cache] module [mod_security] add param [modsecurity_rules_file /usr/local/lsws/conf/modsec/rules.conf]
2023-03-02 11:05:40.405292 [INFO] [PlainConf] [module:cache] module [mod_security] add param [modsecurity_rules_file /usr/local/lsws/conf/modsec/owasp-modsecurity-crs-3.0-master/owasp-master.conf]
2023-03-02 11:05:40.405306 [NOTICE] Loading LiteSpeed/1.7.16 Open (lsquic 3.1.1, modgzip 1.1, cache 1.64, mod_security 1.4) BUILD (built: Thu Nov 17 16:18:46 UTC 2022) …
2023-03-02 11:05:40.405325 [NOTICE] Using [BoringSSL]
2023-03-02 11:05:40.406527 [NOTICE] [ADMIN] server socket: uds://usr/local/lsws/admin/tmp/admin.sock.7735, fd 6.
2023-03-02 11:05:40.406786 [NOTICE] [958951] [:80] Recovering server socket, fd: 8
2023-03-02 11:05:40.406814 [NOTICE] [958951] Recv listener :80, copy fd 1000 to 8.
2023-03-02 11:05:40.406833 [NOTICE] [958951] [:80] SO_REUSEPORT #2, recovering server socket, fd: 9.
2023-03-02 11:05:40.406847 [NOTICE] [958951] [:443] Recovering server socket, fd: 10
2023-03-02 11:05:40.406861 [NOTICE] [958951] Recv listener :443, copy fd 1002 to 10.
2023-03-02 11:05:40.406876 [NOTICE] [958951] [:443] SO_REUSEPORT #2, recovering server socket, fd: 11.
2023-03-02 11:05:40.406915 [NOTICE] [958951] [UDP :443] Recovering server socket, SO_REUSEPORT #2, fd: 13
2023-03-02 11:05:40.406940 [NOTICE] [958951] [[::]:443] Recovering server socket, fd: 14
2023-03-02 11:05:40.406961 [NOTICE] [958951] Recv listener [::]:443, copy fd 1006 to 14.
2023-03-02 11:05:40.406980 [NOTICE] [958951] [[::]:443] SO_REUSEPORT #2, recovering server socket, fd: 15.
2023-03-02 11:05:40.407018 [NOTICE] [958951] [UDP [::]:443] Recovering server socket, SO_REUSEPORT #2, fd: 17
2023-03-02 11:05:40.407033 [NOTICE] [958951] [:7080] Recovering server socket, fd: 18
2023-03-02 11:05:40.407047 [NOTICE] [958951] Recv listener *:7080, copy fd 1010 to 18.
2023-03-02 11:05:40.407085 [NOTICE] [958951] chroot is disabled.
2023-03-02 11:05:40.407101 [INFO] [958951] old priority: 0, new priority: 0
2023-03-02 11:05:40.409534 [INFO] [958951] setuid is allowed in Ext Apps
2023-03-02 11:05:40.409976 [NOTICE] [958951] [PID: 958951]: forked cgid: 958952
2023-03-02 11:05:40.410281 [INFO] [958951] Add QUIC.cloud IPs from admin/conf/quic-cloud-ips to trusted ACL …
2023-03-02 11:05:40.410460 [INFO] [958951] Add CloudFlare Subnets to trusted ACL …
2023-03-02 11:05:40.410571 [INFO] [958951] [PlainConf] [adminConfig:] start parsing file /usr/local/lsws/admin/conf/admin_config.conf
2023-03-02 11:05:40.411023 [INFO] [958951] [PlainConf] [adminConfig:] Finished parsing file /usr/local/lsws/admin/conf/admin_config.conf
2023-03-02 11:05:40.411313 [WARN] [958951] [config:server:tuning] invalid value of :1048576, use default=4096
2023-03-02 11:05:40.411812 [INFO] [958951] QuicEngine::init(), pid: 958951, log level [warn].
2023-03-02 11:05:40.412600 [INFO] [958951] [Module: modcompress 1.1] has been initialized successfully
2023-03-02 11:05:40.412788 [INFO] [958951] [Module: moddecompress 1.1] has been initialized successfully
2023-03-02 11:05:40.413030 [INFO] [958951] [Module: cache 1.64] has been initialized successfully
2023-03-02 11:05:40.414074 [NOTICE] [958951] Reuse current listener [adminListener].
2023-03-02 11:05:40.414180 [WARN] [958951] [config:server:listener] No listener is available for normal virtual host!
2023-03-02 11:05:40.414196 [NOTICE] [958951] The maximum number of file descriptor limit is set to 50000.
2023-03-02 11:05:40.415315 [NOTICE] [958951] [config:server:epsr:lsphp] Possible mis-configuration: ‘Instances’=8, ‘Max connections’=10, unless one Fast CGI process is capable of handling multiple connections, you should set ‘Instances’ greater or equal to ‘Max connections’.
2023-03-02 11:05:40.415524 [NOTICE] [958951] [ZConfManager] No VHosts added, do not send!
2023-03-02 11:05:40.415537 [NOTICE] [958951] Stop listener *:443, fd 10.
2023-03-02 11:05:40.415567 [NOTICE] [958951] Stop listener [::]:443, fd 14.
2023-03-02 11:05:40.415582 [NOTICE] [958951] Stop listener *:80, fd 8.
2023-03-02 11:05:40.416330 [NOTICE] [958951] Instance is ready for service. m_fdCmd 8, m_fdAdmin 6.
2023-03-02 11:05:40.416721 [NOTICE] [958951] [AutoRestarter] new child process with pid=958953 is forked!
2023-03-02 11:05:40.417058 [NOTICE] [958951] [AutoRestarter] new child process with pid=958954 is forked!
2023-03-02 11:05:40.417166 [INFO] [958953] [UDP:0.0.0.0:7080] initPacketsIn: allocated 100 packets
2023-03-02 11:05:40.417355 [NOTICE] [958953] AIO is not supported on this machine!
2023-03-02 11:05:40.417396 [NOTICE] [958953] Successfully change current user to nobody
2023-03-02 11:05:40.417408 [NOTICE] [958953] Core dump is enabled.
2023-03-02 11:05:40.417466 [INFO] [958953] [lsphp]: locked pid file [/tmp/lshttpd/lsphp.sock.pid].
2023-03-02 11:05:40.417479 [INFO] [958953] [lsphp] remove unix socket for detached process: /tmp/lshttpd/lsphp.sock
2023-03-02 11:05:40.417553 [NOTICE] [958953] [LocalWorker::workerExec] Config[lsphp]: suExec uid 65534 gid 65534 cmd /usr/local/lsws/lsphp74/bin/lsphp, final uid 65534 gid 65534, flags: 0.
2023-03-02 11:05:40.417860 [NOTICE] [958953] [lsphp] add child process pid: 958955
2023-03-02 11:05:40.417954 [INFO] [958953] [lsphp]: unlocked pid file [/tmp/lshttpd/lsphp.sock.pid].
2023-03-02 11:05:40.417905 [NOTICE] [958954] Stop listener *:7080, fd 18.
2023-03-02 11:05:40.417979 [NOTICE] [958953] Setup swapping space…
2023-03-02 11:05:40.418061 [NOTICE] [958953] LiteSpeed/1.7.16 Open starts successfully!
2023-03-02 11:05:40.418226 [NOTICE] [958954] AIO is not supported on this machine!
2023-03-02 11:05:40.418293 [NOTICE] [958954] Successfully change current user to nobody
2023-03-02 11:05:40.418310 [NOTICE] [958954] Core dump is enabled.
2023-03-02 11:05:40.418341 [ERROR] [958954] No listener is available, stop server!
2023-03-02 11:05:40.418354 [NOTICE] [958954] HttpServerImpl::releaseAll called.
2023-03-02 11:05:40.419795 [NOTICE] [958951] [AutoRestarter] cleanup children processes and unix sockets belong to process 958954 !
2023-03-02 11:05:40.465781 [NOTICE] [958636] New litespeed process is ready, stops listeners
2023-03-02 11:05:40.465842 [INFO] [958636] Stop all listeners.
2023-03-02 11:05:40.465850 [NOTICE] [958636] Stop listener *:80, fd 9.
2023-03-02 11:05:40.465863 [NOTICE] [958636] Stop listener *:443, fd 11.
2023-03-02 11:05:40.465872 [NOTICE] [958636] Stop listener [::]:443, fd 15.
2023-03-02 11:05:40.465895 [NOTICE] [958636] Event-loop lingering done.
2023-03-02 11:05:40.465901 [NOTICE] [958636] Shut down successfully!
2023-03-02 11:05:40.465909 [NOTICE] [958636] HttpServerImpl::releaseAll called.
2023-03-02 11:05:40.469273 [NOTICE] [958635] New litespeed process is ready, stops listeners
2023-03-02 11:05:40.469293 [INFO] [958635] Stop all listeners.
2023-03-02 11:05:40.469298 [NOTICE] [958635] Stop listener *:80, fd 8.
2023-03-02 11:05:40.469306 [NOTICE] [958635] Stop listener *:443, fd 10.
2023-03-02 11:05:40.469312 [NOTICE] [958635] Stop listener [::]:443, fd 14.
2023-03-02 11:05:40.469317 [NOTICE] [958635] Stop listener *:7080, fd 18.
2023-03-02 11:05:40.469534 [NOTICE] [958633] [AutoRestarter] cleanup children processes and unix sockets belong to process 958636 !
2023-03-02 11:05:40.519982 [NOTICE] [958951] [AutoRestarter] child process with pid=958954 exited with status=0!
2023-03-02 11:05:40.520422 [NOTICE] [958951] [AutoRestarter] new child process with pid=958956 is forked!
2023-03-02 11:05:40.521336 [NOTICE] [958956] Stop listener *:7080, fd 18.
2023-03-02 11:05:40.521700 [NOTICE] [958956] AIO is not supported on this machine!
2023-03-02 11:05:40.521782 [NOTICE] [958956] Successfully change current user to nobody
2023-03-02 11:05:40.521806 [NOTICE] [958956] Core dump is enabled.
