Not able to copy files between accounts folder
Why I am not able to copy files between accounts folders even though i am logged in my root account?
Please help.
using CLI…
then use cp command or you can install midnight commander
if im not wrong
2.1.3 will have root filemanager
cc: @usmannasir @shoaibkk cmiiw
@MyIDKaTePe
I am using CLI, unfortunately the command did not succeed because of a permission issue even when I use a sudoer user or root user. this is weird
if you are root
then it should have full permission
Even with root user I get the following error
root@xyz:/home/foo# cp blah-blah-file-202204091800.zip /home/bar/
cp: cannot create regular file '/home/bar/blah-blah-file-202204091800.zip': Operation not permitted
are you talking about cyberpanel or default linux help ?
cp command will work for this change the user directory to root also show me the folder permissions.
@MyIDKaTePe we will announce soon that while it is coming in 2.2.0 or 2.1.3
root@xyz:/home# ls -lh
drwx--x--x 6 bar  bar  4.0K Apr  8 06:01 bar
drwxr-xr-x 8 foo      foo      4.0K Apr 10 08:06 foo
root@xyz:/home/foo# ls -lh
-rwxrwxr-x 1 bar bar 1.9G Apr  9 18:02 blah-blah-file-202204091800.zip
Changing the file/directory attributes fixed the issue
$ chattr -i -a .
for more info
$ man lsattr
$ man chattr
