No match for argument: MariaDB-server Fresh Installation on Almalinux 9
While installing cyberpanel on Almalinux 9 on Arm processor, I received the following error.
  Please enter the number[1-2]: 1
                CyberPanel Installer v2.4.1
RAM check : 641/23980MB (2.67%)
Disk check : 2/199GB (2%) (Minimal 10GB free space)
1. Install CyberPanel with OpenLiteSpeed.
2. Install Cyberpanel with LiteSpeed Enterprise.
3. Exit.
  Please enter the number[1-3]: 1
Install Full service for CyberPanel? This will include PowerDNS, Postfix and Pur        e-FTPd.
Full installation [Y/n]: Y
Full installation selected...
Do you want to setup Remote MySQL? (This will skip installation of local MySQL)
(Default = No) Remote MySQL [y/N]:
Local MySQL selected...
Press Enter key to continue with latest version or Enter specific version such a        s: 1.9.4 , 2.0.1 , 2.0.2 ...etc
Branch name set to v2.4.1
Please choose to use default admin password 1234567, randomly generate one (reco        mmended) or specify the admin password?
Choose [d]fault, [r]andom or [s]et password: [d/r/s]
Admin password will be provided once installation is completed...
Do you wish to install Memcached process and its PHP extension?
Please select [Y/n]:
Install Memcached process and its PHP extension set to Yes...
Do you wish to install Redis process and its PHP extension?
Install Redis process and its PHP extension set to Yes...
Would you like to set up a WatchDog (beta) for Web service and Database service        ?
The watchdog script will be automatically started up after installation and serv        er reboot
If you want to kill the watchdog , run watchdog kill
Please type Yes or no (with capital Y, default Yes):
Install Watchdog set to Yes...
26 files removed
No match for argument: epel-release
No packages marked for removal.
Dependencies resolved.
Nothing to do.
Complete!
./cyberpanel.sh: line 847: /usr/bin/crb: No such file or directory
bash: line 1: html: No such file or directory
bash: line 2: syntax error near unexpected token `<'
'ash: line 2: `<head><title>301 Moved Permanently</title></head>
AlmaLinux 9 - AppStream                          11 MB/s |  10 MB     00:00
AlmaLinux 9 - BaseOS                            420 kB/s | 8.7 MB     00:21
AlmaLinux 9 - Extras                             19 kB/s |  20 kB     00:01
 Package                Architecture  Version             Repository       Size
Installing:
 libxcrypt-compat       aarch64       4.4.18-3.el9        appstream        93 k
Transaction Summary
Install  1 Package
Total download size: 93 k
Installed size: 198 k
Downloading Packages:
libxcrypt-compat-4.4.18-3.el9.aarch64.rpm       188 kB/s |  93 kB     00:00
Total                                            79 kB/s |  93 kB     00:01
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
  Preparing        :                                                        1/1
  Installing       : libxcrypt-compat-4.4.18-3.el9.aarch64                  1/1
  Running scriptlet: libxcrypt-compat-4.4.18-3.el9.aarch64                  1/1
  Verifying        : libxcrypt-compat-4.4.18-3.el9.aarch64                  1/1
Installed:
Complete!
AlmaLinux 9 - CRB                               1.1 MB/s | 2.2 MB     00:02
Last metadata expiration check: 0:00:01 ago on Mon 09 Jun 2025 05:58:03 AM UTC.
epel-release-latest-9.noarch.rpm                 23 kB/s |  19 kB     00:00
Installing:
 epel-release        noarch        9-10.el9           @commandline         19 k
Transaction Summary
Install  1 Package
Total size: 19 k
Installed size: 26 k
Running transaction
  Preparing        :                                                        1/1
  Installing       : epel-release-9-10.el9.noarch                           1/1
  Running scriptlet: epel-release-9-10.el9.noarch                           1/1
Many EPEL packages require the CodeReady Builder (CRB) repository.
It is recommended that you run /usr/bin/crb enable to enable the CRB repository.
  Verifying        : epel-release-9-10.el9.noarch                           1/1
Installed:
Complete!
Extra Packages for Enterprise Linux 9 - aarch64 2.1 MB/s |  20 MB     00:09
Extra Packages for Enterprise Linux 9 openh264  1.2 kB/s | 2.5 kB     00:02
Last metadata expiration check: 0:00:01 ago on Mon 09 Jun 2025 05:58:25 AM UTC.
remi-release-9.rpm                               45 kB/s |  32 kB     00:00
Installing:
 remi-release       noarch       9.5-2.el9.remi        @commandline        32 k
Transaction Summary
Install  1 Package
Total size: 32 k
Installed size: 34 k
Running transaction
  Preparing        :                                                        1/1
  Installing       : remi-release-9.5-2.el9.remi.noarch                     1/1
  Verifying        : remi-release-9.5-2.el9.remi.noarch                     1/1
Installed:
Complete!
Remi's Modular repository for Enterprise Linux  387 kB/s | 721 kB     00:01
Safe Remi's RPM repository for Enterprise Linux 599 kB/s | 1.1 MB     00:01
Last metadata expiration check: 0:00:01 ago on Mon 09 Jun 2025 05:58:36 AM UTC.
Nothing to do.
Complete!
Last metadata expiration check: 0:00:03 ago on Mon 09 Jun 2025 05:58:36 AM UTC.
Package wget-1.21.1-8.el9_4.aarch64 is already installed.
Package curl-7.76.1-31.el9.aarch64 is already installed.
Package which-2.21-29.el9.aarch64 is already installed.
  * Maybe you meant: mariadb-server
No match for argument: MariaDB-client
No match for argument: MariaDB-devel
  * Maybe you meant: mariadb-devel
Package tar-2:1.34-7.el9.aarch64 is already installed.
Package python3-3.9.21-2.el9.aarch64 is already installed.
Error: Unable to find a match: MariaDB-server MariaDB-client MariaDB-devel
above command failed...
The MariaDB repo did not exist, so it can be created with this command:
vi /etc/yum.repos.d/mariadb.repo
The contents of the repo:
# MariaDB 10.11 RedHatEnterpriseLinux repository list - created 2025-09-10 17:41 UTC
# https://mariadb.org/download/
[mariadb]
name = MariaDB
# rpm.mariadb.org is a dynamic mirror if your preferred mirror goes offline. See https://mariadb.org/mirrorbits/ for details.
baseurl = https://mirror.mariadb.org/yum/10.11/almalinux9-aarch64/
gpgkey = https://mirrors.xtom.com/mariadb/yum/RPM-GPG-KEY-MariaDB
gpgcheck = 1
This is setup for version 10.11. If you want a different version, use a browser to see what is available here:
Also need to choose the right OS and processor, after clicking on the version number in the browser.
After saving, I ran the install again, it successfully installed Cyberpanel 2.4,4. This is on Alma Linux 9, installed using Vagrant with a Parallels VM on an M1 Mac.
Terry
Will be fixed in V2.5.5-dev
I have already pushed an update for this.
