Hi team, I receive this warning message during cyberpanel Installation ( Centos 7 ) whats mean?
Provider: Cloud4box
Virtualization Type: VMZ ( i guess)
System: CentOS-7-amd64
Installation option: since during the installation.
OLS or Enterprise?
OLS
mirror
yes
yes
Install LiteSpeed Memcached?
yes
Install Memcached?
yes
yes
Install Redis?
yes
Problem:
?: (mysql.W002) MySQL Strict Mode is not set for database connection ‘default’
HINT: MySQL’s Strict Mode fixes many data integrity problems in MySQL, such as data truncation upon insertion, by escalating warnings into errors. It is strongly recommended you activate it. See: https://docs.djangoproject.com/en/1.11/ref/databases/…
?: (mysql.W002) MySQL Strict Mode is not set for database connection ‘rootdb’
and the installation process stopped here:
Applying websiteFunctions.0001_initial…^CTraceback (most recent call last):
File “install.py”, line 3773, in
main()
File “install.py”, line 3723, in main
checks.download_install_CyberPanel(installCyberPanel.InstallCyberPanel.mysqlPassword, mysql)
File “install.py”, line 1042, in download_install_CyberPanel
‘CyberPanel Migrate’,1, 1, os.EX_OSERR)
File “install.py”, line 211, in call
res = subprocess.call(shlex.split(command))
File “/usr/lib64/python2.7/subprocess.py”, line 524, in call
return Popen(*popenargs, **kwargs).wait()
File “/usr/lib64/python2.7/subprocess.py”, line 1376, in wait
pid, sts = _eintr_retry_call(os.waitpid, self.pid, 0)
File “/usr/lib64/python2.7/subprocess.py”, line 478, in _eintr_retry_call
return func(*args)
KeyboardInterrupt
Something went wrong…
[root@vps ~]# Traceback (most recent call last):
File “manage.py”, line 22, in
File “/usr/lib64/python2.7/site-packages/django/core/management/init.py”, line 363, in execute_from_command_line
utility.execute()
File “/usr/lib64/python2.7/site-packages/django/core/management/init.py”, line 355, in execute
File “/usr/lib64/python2.7/site-packages/django/core/management/base.py”, line 283, in run_from_argv
File “/usr/lib64/python2.7/site-packages/django/core/management/base.py”, line 330, in execute
output = self.handle(*args, **options)
File “/usr/lib64/python2.7/site-packages/django/core/management/commands/migrate.py”, line 204, in handle
fake_initial=fake_initial,
File “/usr/lib64/python2.7/site-packages/django/db/migrations/executor.py”, line 115, in migrate
state = self._migrate_all_forwards(state, plan, full_plan, fake=fake, fake_initial=fake_initial)
File “/usr/lib64/python2.7/site-packages/django/db/migrations/executor.py”, line 145, in _migrate_all_forwards
state = self.apply_migration(state, migration, fake=fake, fake_initial=fake_initial)
File “/usr/lib64/python2.7/site-packages/django/db/migrations/executor.py”, line 244, in apply_migration
state = migration.apply(state, schema_editor)
File “/usr/lib64/python2.7/site-packages/django/db/migrations/migration.py”, line 129, in apply
operation.database_forwards(self.app_label, schema_editor, old_state, project_state)
File “/usr/lib64/python2.7/site-packages/django/db/migrations/operations/models.py”, line 97, in database_forwards
schema_editor.create_model(model)
File “/usr/lib64/python2.7/site-packages/django/db/backends/base/schema.py”, line 302, in create_model
self.execute(sql, params or None)
File “/usr/lib64/python2.7/site-packages/django/db/backends/base/schema.py”, line 119, in execute
cursor.execute(sql, params)
File “/usr/lib64/python2.7/site-packages/django/db/backends/utils.py”, line 63, in execute
return self.cursor.execute(sql)
File “/usr/lib64/python2.7/site-packages/django/db/backends/mysql/base.py”, line 101, in execute
return self.cursor.execute(query, args)
File “/usr/lib64/python2.7/site-packages/MySQLdb/cursors.py”, line 190, in execute
r = self._query(query)
File “/usr/lib64/python2.7/site-packages/MySQLdb/cursors.py”, line 354, in _query
rowcount = self._do_query(q)
File “/usr/lib64/python2.7/site-packages/MySQLdb/cursors.py”, line 318, in _do_query
db.query(q)
KeyboardInterrupt
