CyberPanel Community
My Design CSS:
MK
Mirza Khadnezar S [sick] #1
Hello
this is not perfect, but who knows someone here can make it better
dear admin:
can you lock the color as per user
or only admin can change the color ?
.bg-default, .bg-white.dashboard-box .button-pane, .bg-white.tile-box .tile-footer, .border-default, .bordered-row .form-group, .btn-default, .button-pane, .chosen-container, .chosen-container .chosen-drop, .chosen-container-active.chosen-with-drop .chosen-single div, .chosen-container-multi .chosen-choices li.search-choice, .chosen-container-single .chosen-single div, .content-box, .content-box-header.bg-default, .content-box-header.bg-gray, .content-box-header.bg-white, .dashboard-buttons .btn, .daterangepicker .calendar-date, .dropdown-menu, .email-body, .fc-state-default, .fc-widget-content, .fc-widget-header, .img-thumbnail, .jvectormap-label, .jvectormap-zoomin, .jvectormap-zoomout, .list-group-item, .mail-toolbar, .mailbox-wrapper .nav-list li a, .minicolors-panel, .ms-container .ms-list, .ms-container .ms-selectable li.ms-elem-selectable, .ms-container .ms-selection li.ms-elem-selection, .nav .open>a, .nav .open>a:focus, .nav .open>a:hover, .nav-tabs, .nav-tabs>li>a:focus, .nav-tabs>li>a:hover, .pagination>li>a, .pagination>li>span, .panel, .panel-box.bg-default, .panel-box.bg-gray, .panel-box.bg-white, .panel-content.bg-default, .panel-content.bg-gray, .panel-content.bg-white, .panel-footer, .panel-group .panel-footer+.panel-collapse .panel-body, .panel-group .panel-heading+.panel-collapse .panel-body, .panel-heading, .popover, .popover-title, .posts-list li, .selector i, .table-bordered, .table>tbody>tr>td, .table>tbody>tr>th, .table>tfoot>tr>td, .table>tfoot>tr>th, .table>thead>tr>td, .table>thead>tr>th, .tabs-navigation>ul, .tabs-navigation>ul li.ui-state-hover>a, .tabs-navigation>ul li>a, .thumb-pane, .thumbnail, .timeline-box .tl-item .popover, .timeline-box:before, .ui-accordion .ui-accordion-header, .ui-datepicker, .ui-datepicker .ui-datepicker-buttonpane button, .ui-datepicker-buttonpane, .ui-dialog, .ui-dialog .ui-dialog-titlebar, .ui-dialog-buttonpane, .ui-menu, .ui-spinner .ui-spinner-button, .ui-tabs-nav, div.selector, div[id^=uniform-] span {
border-radius: 90px;
.bg-gradient-9 {
background: linear-gradient(
-90deg
, #212025 0%, #000 70%);
#page-content {
    background: #1D1D21;
h1, h2, h3, h4, h5, h6, #page-title > h2, #page-title > p {
    font-family: "Raleway", "Helvetica Neue", Helvetica, Arial, sans-serif;
    font-weight: 300;
    color: whitesmoke;
#page-title h2 {
    font-size: 22px;
    text-transform: uppercase;
    padding: 0;
    font-weight: 100;
    margin: 0;
    color: cyan;
.panel-body {
    padding: 15px 20px;
    position: relative;
    background-color: #ECECEC;
    border-radius: 30px;
.mx-10 {
    margin-left: 10px;
    margin-right: 10px;
    content-visibility: auto;
.content-box-header {
    font-size: 14px;
    margin: -1px -1px 0;
    padding: 15px;
    border-color: transparent;
    color: darkmagenta;
MK
Mirza Khadnezar S [sick] #2
New:
Change the gradient from -90 to 90 and remove the white body (i hope)
border: 0px;
.bg-gradient-9 {
90deg
, #212025 0%, #000 200%);
#header-logo, #page-header {
    height: 78px;
    background-color: #1D1D21;
body {
#page-content {
    font-weight: 300;
    color: whitesmoke;
#page-title h2 {
    font-size: 22px;
    padding: 0;
    font-weight: 100;
    margin: 0;
    color: cyan;
.panel-body {
    padding: 15px 20px;
    position: relative;
.mx-10 {
    margin-left: 10px;
    margin-right: 10px;
    font-size: 14px;
    padding: 15px;
    color: darkmagenta;
NK
Nitesh Kunnath #3
Which color are you talking about?
NK
Nitesh Kunnath #5
You can change anything via CSS… Most of the things can be changed including cyberpanel logo.
