Requirements for every topic created
Server os version Ubuntu 20.04
Current Version: 2.3
Build: 2
Current Commit: bb6d095a5362deccf8166759ce69d8576eafc7c7
Latest Version: 2.3
Latest Build: 4
Latest Commit: a47d41a3741c46a4130d81f0db7adf176c198840
- I created a website and within it, in manager I pointed out some alias domains. It directs if you try to access these other domains. But it does not generate ssl. whenever I click on issue ssl it disfigures the main domain. Another problem is that I am not able to delete the domain aliases
[06.06.2023_03-46-01] Record already exists.. [createDNSRecordCloudFlare]
[06.06.2023_03-46-02] Record already exists.. [createDNSRecordCloudFlare]
[06.06.2023_03-46-03] Record already exists.. [createDNSRecordCloudFlare]
[06.06.2023_12-12-00] Status Code: 200 for: http://www.lp.riseads.com.br/.well-known/acme-challenge/lp.riseads.com.br
[06.06.2023_12-12-00] Status Code: 200 for: http://lp.riseads.com.br/.well-known/acme-challenge/lp.riseads.com.br
[06.06.2023_12-12-02] Trying to obtain SSL for: lp.riseads.com.br, www.lp.riseads.com.br, class-academy.com and www.class-academy.com,
[06.06.2023_12-12-09] Failed to obtain SSL for: lp.riseads.com.br, www.lp.riseads.com.br, class-academy.comand www.class-academy.com,
[06.06.2023_12-12-09] Self signed SSL issued for lp.riseads.com.br.
[06.06.2023_12-39-35] Status Code: 200 for: http://www.lp.riseads.com.br/.well-known/acme-challenge/lp.riseads.com.br
[06.06.2023_12-39-35] Status Code: 200 for: http://lp.riseads.com.br/.well-known/acme-challenge/lp.riseads.com.br
[06.06.2023_12-39-37] /root/.acme.sh/acme.sh --issue -d lp.riseads.com.br -d www.lp.riseads.com.br --cert-file /etc/letsencrypt/live/lp.riseads.com.br/cert.pem --key-file /etc/letsencrypt/live/lp.riseads.com.br/privkey.pem --fullchain-file /etc/letsencrypt/live/lp.riseads.com.br/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
[06.06.2023_12-39-41] Successfully obtained SSL for: lp.riseads.com.br and: www.lp.riseads.com.br
[06.06.2023_12-39-41] {'[email protected]': (554, b'5.7.1 <[email protected]>: Relay access denied')}
[06.06.2023_12-40-19] Status Code: 200 for: http://www.lp.riseads.com.br/.well-known/acme-challenge/lp.riseads.com.br
[06.06.2023_12-40-19] Status Code: 200 for: http://lp.riseads.com.br/.well-known/acme-challenge/lp.riseads.com.br
[06.06.2023_12-40-21] /root/.acme.sh/acme.sh --issue -d lp.riseads.com.br -d www.lp.riseads.com.br --cert-file /etc/letsencrypt/live/lp.riseads.com.br/cert.pem --key-file /etc/letsencrypt/live/lp.riseads.com.br/privkey.pem --fullchain-file /etc/letsencrypt/live/lp.riseads.com.br/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
[06.06.2023_12-40-22] Failed to obtain SSL for: lp.riseads.com.br and: www.lp.riseads.com.br
[06.06.2023_12-40-22] Trying to obtain SSL for: lp.riseads.com.br
[06.06.2023_12-40-26] Successfully obtained SSL for: lp.riseads.com.br
[06.06.2023_12-40-26] {'[email protected]': (554, b'5.7.1 <[email protected]>: Relay access denied')}
[06.06.2023_12-46-22] DNS Validation Error. [createDNSRecordCloudFlare]
[06.06.2023_12-46-23] A CNAME record with that host already exists. For more details, refer to <https://developers.cloudflare.com/dns/manage-dns-records/troubleshooting/records-with-same-name/>.. [createDNSRecordCloudFlare]
[06.06.2023_12-46-32] Status Code: Unknown for: http://www.purevitacaps.com/.well-known/acme-challenge/purevitacaps.com. Error: HTTPConnectionPool(host='www.purevitacaps.com', port=80): Max retries exceeded with url: /.well-known/acme-challenge/purevitacaps.com (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7fe1d5f0d390>: Failed to establish a new connection: [Errno -2] Name or service not known'))
[06.06.2023_12-46-32] Status Code: 200 for: http://purevitacaps.com/.well-known/acme-challenge/purevitacaps.com
[06.06.2023_12-46-36] /root/.acme.sh/acme.sh --issue -d purevitacaps.com -d www.purevitacaps.com --cert-file /etc/letsencrypt/live/purevitacaps.com/cert.pem --key-file /etc/letsencrypt/live/purevitacaps.com/privkey.pem --fullchain-file /etc/letsencrypt/live/purevitacaps.com/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
[06.06.2023_12-46-51] Successfully obtained SSL for: purevitacaps.com and: www.purevitacaps.com
[06.06.2023_12-46-51] {'[email protected]': (554, b'5.7.1 <[email protected]>: Relay access denied')}
[06.06.2023_12-46-51] Websites matching query does not exist. [installSSLForDomain:72]
[06.06.2023_12-49-30] Record already exists.. [createDNSRecordCloudFlare]
[06.06.2023_12-49-30] DNS Validation Error. [createDNSRecordCloudFlare]
[06.06.2023_12-49-30] A CNAME record with that host already exists. For more details, refer to <https://developers.cloudflare.com/dns/manage-dns-records/troubleshooting/records-with-same-name/>.. [createDNSRecordCloudFlare]
[06.06.2023_12-49-30] An A, AAAA, or CNAME record with that host already exists. For more details, refer to <https://developers.cloudflare.com/dns/manage-dns-records/troubleshooting/records-with-same-name/>.. [createDNSRecordCloudFlare]
[06.06.2023_12-49-31] Record already exists.. [createDNSRecordCloudFlare]
[06.06.2023_12-49-36] Status Code: Unknown for: http://www.purevitacaps.com/.well-known/acme-challenge/purevitacaps.com. Error: HTTPConnectionPool(host='www.purevitacaps.com', port=80): Max retries exceeded with url: /.well-known/acme-challenge/purevitacaps.com (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f480a1c7220>: Failed to establish a new connection: [Errno -2] Name or service not known'))
[06.06.2023_12-49-36] Status Code: 200 for: http://purevitacaps.com/.well-known/acme-challenge/purevitacaps.com
[06.06.2023_12-49-38] /root/.acme.sh/acme.sh --issue -d purevitacaps.com -d www.purevitacaps.com --cert-file /etc/letsencrypt/live/purevitacaps.com/cert.pem --key-file /etc/letsencrypt/live/purevitacaps.com/privkey.pem --fullchain-file /etc/letsencrypt/live/purevitacaps.com/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
[06.06.2023_12-49-42] Successfully obtained SSL for: purevitacaps.com and: www.purevitacaps.com
[06.06.2023_12-49-42] {'[email protected]': (554, b'5.7.1 <[email protected]>: Relay access denied')}
[06.06.2023_13-20-15] https://api.github.com/repos/usmannasir/cyberpanel/commits?sha=v2.3.4
### Rewrite Rules Added by CyberPanel Rewrite Rule Generator
RewriteEngine On
RewriteRule ^/(xmlrpc|wp-trackback).php - [F,L,NC]
### End CyberPanel Generated Rules.
RewriteEngine On
RewriteCond %{HTTP_HOST} ^www.(.*)$
RewriteRule ^(.*)$ http://%1/$1 [L,R=301]
RewriteEngine On
RewriteCond %{HTTPS} !=on
RewriteRule ^/?(.*) https://%{SERVER_NAME}/$1 [R,L]
#BEGIN Really Simple SSL LETS ENCRYPT
RewriteRule ^.well-known/(.*)$ - [L]
#END Really Simple SSL LETS ENCRYPT
RewriteEngine On
cat: /home/lebelleesteticaavancada.com.br/public_html/.htaccess: No such file or directory
# BEGIN WordPress
# The directives (lines) between "BEGIN WordPress" and "END WordPress" are
# dynamically generated, and should only be modified via WordPress filters.
# Any changes to the directives between these markers will be overwritten.
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
RewriteBase /
RewriteRule ^index\.php$ - [L]
RewriteRule . /index.php [L]
</IfModule>
# END WordPress
# BEGIN FRedirect_ErrorDocument
# The directives (lines) between "BEGIN FRedirect_ErrorDocument" and "END FRedirect_ErrorDocument" are
ErrorDocument 404 /index.php?error=404
# END FRedirect_ErrorDocument
docRoot $VH_ROOT/public_html
vhDomain $VH_NAME
vhAliases www.$VH_NAME
adminEmails [email protected]
enableGzip 1
enableIpGeo 1
index {
useServer 0
indexFiles index.php, index.html
errorlog $VH_ROOT/logs/$VH_NAME.error_log {
useServer 0
logLevel WARN
rollingSize 10M
accesslog $VH_ROOT/logs/$VH_NAME.access_log {
useServer 0
logFormat "%h %l %u %t "%r" %>s %b "%{Referer}i" "%{User-Agent}i""
logHeaders 5
rollingSize 10M
keepDays 10
compressArchive 1
scripthandler {
add lsapi:lpris9356 php
extprocessor lpris9356 {
type lsapi
address UDS://tmp/lshttpd/lpris9356.sock
maxConns 10
env LSAPI_CHILDREN=10
initTimeout 600
retryTimeout 0
persistConn 1
pcKeepAliveTimeout 1
respBuffer 0
autoStart 1
path /usr/local/lsws/lsphp81/bin/lsphp
extUser lpris9356
extGroup lpris9356
memSoftLimit 2047M
memHardLimit 2047M
procSoftLimit 400
procHardLimit 500
phpIniOverride {
module cache {
storagePath /usr/local/lsws/cachedata/$VH_NAME
rewrite {
enable 1
autoLoadHtaccess 1
context /.well-known/acme-challenge {
location /usr/local/lsws/Example/html/.well-known/acme-challenge
allowBrowse 1
rewrite {
addDefaultCharset off
phpIniOverride {
vhssl {
keyFile /etc/letsencrypt/live/lp.riseads.com.br/privkey.pem
certFile /etc/letsencrypt/live/lp.riseads.com.br/fullchain.pem
certChain 1
sslProtocol 24
enableECDHE 1
renegProtection 1
sslSessionCache 1
enableSpdy 15
enableStapling 1
ocspRespMaxAge 86400
