I found cyber panel very good solution only for -
1 ) Good for Small / Uncritical website hosting
2 ) Good if you are not looking to perform commercial business on it
Here why I am pointing/explanation -
1 ) CyberPanel still has many bugs and due to a very small team and a lot of dependency on a single person, its will always litle bit delay in a fix. It is not like another panel provider where proper testing is done before release or having a huge team for each role.
2 ) Since it’s free, you can not ask or force anything on anyone. Responsibility if missing.
3 ) Support service is not quick and you have to depend on the community/forum or CyberPanel response. The only user who using it or directly CyberPanel team will help you, So you can not expect support quickly. Sometimes, tickets or issue go without a response/rejected.
4 ) CyberPanel is ok for a small project where you cannot be directly responsible for anyone.
5 ) Platform dependancy - If you once onboard, maybe not easy to back to direct admin or cPanel or another panel since export-import plugin not available.
6 ) Not able to found the company ( 3rd party ) who externally provide support if required.
There are issues that may be due to human resources and funding, Project Manager doing a great job, whatever he can do best.
If you have patience and time, can use it with good hope.
My first-day excitement and current definitely little bit lower but still I am hoping good in coming days.
@CyberPanel @cybertech @litespeed
Looking for others and teams a ( positive ) response, since I am here to make this product success. Sometimes pointing issue also helps both - user and provider.
