Is it possible to change default CyberPanel port or to make it accessible from the subdomain?
I’m aware of brute forcing login knowing the default port.
Currently changing port is not allowed, however, you can access CyberPanel via any domain on your server (with valid DNS record), you can also issue SSL for it 2 - CyberPanel on SSL - 03 - SSL - CyberPanel Community
Thanks, already did it. Will stay tuned!
