I want a suggestion on moving my existing live site from Cloudways to Vultr+Cyberpanel. What would be the optimized way of doing that without loosing rank in google or least possible down time.
Use migration plugin like migrate guru and if you wont change domain you don’t need worry about google rank.
The site is big enough so uploading it using plugin might break it
Then just do it manually by moving files and database.
