Mautic installation fails due to curl extension
I created the website and im trying to install mautic but the installation fails with this error
Installation failed. Error message: [“Mautic Install”,“==============”,“”,“Parsing options and arguments…”,“0 - Checking installation requirements…”,“Missing requirements:”," - [0] Install and enable the curl extension.“,“Install canceled”,” [404]"]
I have curl installed but I reinstalled it but I keep getting same message.
this is what i get in the browser.
Mautic does not support PHP version 8.1.14 at this time. To use Mautic, you will need to downgrade to an earlier version.
I installed sudo apt-get install php-curl
but still no go. I tried all other version of PHP like 7.4,3,2,1 but no go.
I have cyberpanel installed on ubuntu 22.04
Ramdhan Mubarak @sheikh73
What error are you getting so far using php7.4 ?
Same message. I tried again with 7.4 which is recommended I get this message
Installation failed. Error message: ["PHP Warning: PHP Startup:
Unable to load dynamic library 'curl' (tried: /usr/local/lsws/lsphp74/lib/php/20190902/curl (/usr/local/lsws/lsphp74/lib/php/20190902/curl: cannot open shared object file: No such file or directory), /usr/local/lsws/lsphp74/lib/php/20190902/curl.so (/usr/local/lsws/lsphp74/lib/php/20190902/curl.so: cannot open shared object file:
No such file or directory)) in Unknown on line 0","Mautic Install","==============","","Parsing options and arguments...","0 - Checking installation requirements...","Missing requirements:"," - [0] Install and enable the <strong>curl</strong> extension.","Install canceled"," [404]"]
I deleted the website and recreated every attempt of nautic. This time with php7.3 I don’t see mautic app available to install. What happened. I create website again to check
Mautic only works with PHP 7.4 and 8.0.
Also check what your memory limit and other php configuration is before installing Mautic.
I installed Centos7 and then installed mautic and it worked. I think ubuntu is not an os for it.
This issue is very clear you do have dynamic library curl for php7.4
and how can we fix it?
I just installed centos7 and installed cyberpanel and then Mautic. All went well
In Ubuntu when I was trying to install mautic I deleted and created website with ssl so many times. Now when I’m trying to issue a ssl certificate. I get error message.
This means Mautic Installtion went well. The only issue is Mautic unreleated. What error are you getting ?
Mautic is not OS specific. Kindly read through the documentation Requirements - Mautic Community
