I have a problem with the virtual host. I have a domain and subdomain for Cyberpanel. For the domain everything is fine, but the vhost for the subdomain shows that the default listener is unavailable.
I can’t edit httpd.conf because it is generated automatically. Can I configure it manually to fix the problem?
2023-01-02 12:22:59.485588 [INFO] [992] [T0] Processing config file: /usr/local/lsws/conf/vhosts/EXAMPLE.COM/vhost.conf
2023-01-02 12:22:59.486403 [INFO] [992] [T0] Processing config file: /usr/local/lsws/conf/vhosts/panel.EXAMPLE.COM/vhost.conf
2023-01-02 12:22:59.495216 [ERROR] [992] [T0] [/usr/local/lsws/conf/vhosts/panel.EXAMPLE.COM/vhost.conf:34] Listener for _default_ is not available.
[Mon Jan 2 12:22:59 2023] [notice] Finish reading Apache configuration, server configured -- resuming normal operations
Ubuntu 20.4 | LSWS | Cyberpanel 2.3 Build 2.
