I have been trying to install cyberpanel on almalinux and for some odd reason can’t run php -v command because it says php not found. Error when running phpmyadmin - Composer detected issues in your platform: Your Composer dependencies require the following PHP extensions to be installed: json
Json is already installed - Is cyberpanel not compatible with almalinux?
