Language selection doesnt work with fresh 1.9.3.
Provider: Self
Virtualization Type: Dedicated Server
System: Centos 7.7 ,
Installation option:
OLS or Enterprise?
OLS
official
no
Yes
Install LiteSpeed Memcached?
yes
Install Memcached?
Yes
yes
Install Redis?
yes
Problem:
I have 2 new installation with 1.9.3, language selection doesnt on login screen doesnt affect. Tried with Major languages which I knew that was working previously like ( Russian etc.) None of them works.
However I have another instance which I updated from 1.9.0 to 1.9.3 all works fine.
I was checking with people from Discord seems like some other people also have the issue with language. Can you help please.
Thanks
Fixed → fix language selection: https://forums.cyberpanel.net/discussion/3662… · usmannasir/cyberpanel@8a2a6c6 · GitHub
