Hello All,
Anyone have a solution for this, after installing Mautic?
After installing on my domain I get this.
index.php and index.html are in the public_html
Thanks
Hello All,
Thanks
if number 1&2 result is same. and number 3 display the screenshoot correctly
then you have DNS Cache problem, it can be from your proxy/ISP
–or–
use file manager (you can see the complete file there)
to make sure…
create 1 folder e.g. foldername : mysite
create index.html there with text
<hr>
test
<hr>
test just browsed it
https://yoursite,tld/mysite/index.html
if it working
then that is only DNS / CACHE Problem
Hi MyIDKaTePe,
check your NS… pointed to your Cyberpanel or not ?
–or IN A to your IP–
that mean mbo.hipamo.com is not same address with your new index.html
185.87.187.218 ← is this your cyberpanel server that hosted mbo.hipamo.com ?
because i found Login - CyberPanel (hipamo.com IN A 141.144.204.122
also you must check this
fyi: 185.87.187.218 = cpanel not cyberpanel
Hello MyIDKaTePe, so according to you it is because of the DNS?
Sorry, I’m a lightweight in this area.
Putting physical websites in the DNS still works but virtual (VPS) ones don’t work so well yet.
I’m going to take a course on Udemy.
Could you tell me what I need to write in the DNS of my host provider and what I have to delete?
Thank you so much!
first:
you want to point domain to cyberpanel using NS or IN A ?
