Hi there,
I’m trying to install PHP zip extention with PHP8.1, but getting this error
root@server: /usr/local/lsws/lsphp80/bin# /usr/local/lsws/lsphp80/bin/pecl install zip
WARNING: channel "pecl.php.net" has updated its protocols, use "pecl channel-update pecl.php.net" to update
downloading zip-1.22.2.tgz ...
Starting to download zip-1.22.2.tgz (363,869 bytes)
..........................................................................done: 363,869 bytes
24 source files, building
running: phpize
Configuring for:
PHP Api Version: 20200930
Zend Module Api No: 20200930
Zend Extension Api No: 420200930
shtool at '/tmp/pear/install/zip/build/shtool' does not exist or is not executable.
Make sure that the file exists and is executable and then rerun this script.
ERROR: `phpize' failed
