Provider: Virtual Machine under VMWare Workstation 15
Virtualization Type: VMWare
System: Centos 7.7 & Ubuntu 18.04
Installation option:
OLS or Enterprise?
OLS
official
N/A
Install LiteSpeed Memcached?
N/A
Install Memcached?
N/A
N/A
Install Redis?
N/A
Problem:
When I try to install CyberPanel under VMWare minimal CentOS 7 or Ubuntu 18.04 basic server, install fails. On CentOS 7 it show following error message
command: /usr/local/CyberPanel/bin/python3 -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-fg156h2x/MarkupSafe/setup.py'"'"'; __file__='"'"'/tmp/pip-install-fg156h2x/MarkupSafe/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\\r\
‘"’"’);f.close();exec(compile(code, file, ‘"’"‘exec’"’"’))’ egg_info --egg-base /tmp/pip-install-fg156h2x/MarkupSafe/pip-egg-info
cwd: /tmp/pip-install-fg156h2x/MarkupSafe/
Complete output (5 lines):
File “”, line 1, in
File “/tmp/pip-install-fg156h2x/MarkupSafe/setup.py”, line 3, in
from setuptools import setup, Extension, Feature
ImportError: cannot import name ‘Feature’
ERROR: Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
command failed, exiting…
I tried re-install on clean Ubuntu 18.04 VM but same issue occurred
I don’t think this is caused by VMWare enviroment but I might be wrong.
